Maximum shot on a 2000 V6 without engine wear - Mustang Evolution
Old 08-07-2003, 01:35 AM   #1
Send a message via AIM to ASSEMbler
What is the max shot I'd want to do without having to worry about excessive wear? I'm not quite at forged internals so I don't want to blow any gaskets or wear down anything.
ASSEMbler is offline   Reply With Quote
Old 08-07-2003, 04:52 AM   #2
Danger Dude's Avatar
a safe shot would be a 75 wet shot. anything more and you would need a good tune
Old 08-07-2003, 07:07 AM   #3
Send a message via AIM to el cheapo
unfortunately with n2o you want no engine wear, it means no n2o. Any time you add a power adder, you increase your engine wear. Engines are rated at horsepower-hours. So the more hp the less hours.
damn it school, why do you suck so bad??
el cheapo is offline   Reply With Quote
Old 08-07-2003, 11:29 AM   #4
Monkey's Avatar
100 shot occasionally. but due to the split port design, there are 2 runners for every cylinder (12 runners total). the higher the shot, the more likely you are to go lean in the corner cylinders due to the nitrous and fuel not seperating properly and all going into the middle cylinders.
75 shot is safe for all the time, but you can do 100 if you goto the track for a couple runs. i wouldnt do it often though w/o a good tune... (even then i wouldnt do it often on a split port)
Old 08-07-2003, 11:52 AM   #5
tire's Avatar
Send a message via AIM to tire
do you think a 100 shot on 21#er's would lean out near redline? i'm not thinking they would, but it would probably be close.
tire is offline   Reply With Quote
Old 08-07-2003, 12:13 PM   #6
Monkey's Avatar
as long as its a wet shot, no.. the nitrous is tapped from the fuel pump and the fuel rail. the nitrous and fuel mixture are mixed even before the injectors. the injectors just do the normal amount for the incoming air supplied. the nitrous already has the proper amount of fuel.
you could run a 100 shot on 14#. i just wouldnt suggest it w/o a fuel pump ugrade... people get larger injectors when running nitrous for safety and they will make it run a little rich just in case.
Old 08-07-2003, 05:50 PM   #7
tire's Avatar
HAHAHAHA talk about a brain fart.
thanks Brandon, i'm such a ***.
Old 08-08-2003, 05:26 PM   #8
SIG REMOVED FOR THE PRUDE
Old 08-08-2003, 05:32 PM   #9
Old 08-08-2003, 06:10 PM   #10
Joshness is offline   Reply With Quote
Old 08-09-2003, 12:10 AM   #11
Monkey's Avatar
Old 08-09-2003, 07:50 AM   #12
Old 08-09-2003, 03:38 PM   #13
tire's Avatar
Old 08-09-2003, 07:45 PM   #14
Old 09-16-2003, 09:31 PM   #15
Send a message via AIM to v6stanger
I would run a 75 shot on a nitrous express kit. 99+ pumps are pretty good but it can't hurt to spend another 100.00 to upgrade to be completely safe.
75 shot NX ranges from 70-80rwhp and 75-100rwtq depending on mods.
Just change plugs every few thousand miles if you spray alot and check your fuel filter/nitrous filter and run good 93 (sunoco,amoco etc)
Zach
v6stanger is offline   Reply With Quote
Old 10-26-2003, 07:21 PM   #16
Send a message via AIM to 02whitestang
what kind on fuel upgrades do you recomend to be safe, also what kind of plugs?
02whitestang is offline   Reply With Quote
Old 11-25-2003, 11:14 AM   #17
i like those NGK iridium tiped plugs, but anything thats not copper would do, make sure they are a couple degrees colder than stock, get a new fuel pump, a 155 - 255!
that should hold you over for a while
hopeing i get this black on grey 96 5 speed sixxer
but i already have a 87 5.0 coupe, and a 94 regal for my daily beater(until i get the black car *wish me luck*)
notav8 is offline   Reply With Quote
Old 11-25-2003, 11:30 AM   #18
What is wrong with copper. Hell almost everyone I know with nitrous uses copper
Do you want to see Iridium plugs at work in a Nitrous or SC car !!!!
Old 11-25-2003, 11:33 AM   #19
plugs
Yummy. Plug roast.
Old 11-25-2003, 11:39 AM   #20
Zim
You want to **** me?
Zim's Avatar
running a 100 shot on a single port should be ok though with a fuel pump upgrade correct?
I like toys
Old 11-25-2003, 12:42 PM   #21
Monkey's Avatar
yes, but i would look into slightly retarded timing
Old 11-25-2003, 12:43 PM   #22
If you run 100 shot you need to have the timing retarded almost 4*
2000 v6 to gt engine swap? Help CHILE10_STANG Pre-2005 V6 Mustang 2 06-30-2009 10:14 PM
Engine Noise @ 2000 RPM + megax29 Pre-2005 V6 Mustang 8 08-28-2008 02:26 PM
Why you wear seatbelts!! at7311 The Bar 14 07-24-2008 01:54 PM
2000 mustang GT tapping sound in engine dreamcar00 1996-2004 Mustang GT 8 01-19-2007 04:58 PM
08:49 PM
