installed my cai today - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 07-26-2009, 12:00 AM   #1
Senorjizzy is unknown around these parts
Send a message via Yahoo to Senorjizzy
Talking installed my cai today
i just recently got a cai, installed it just a few hours ago (more like 7 cst). and i dont feel much, not that i expexted to, but it sounds way different. sounds deeper, and theres a whistling sound when i press on the gas. i did have a problem with the MAF when i was unscrewing it. i was loosening the nut on it to get it to finger loose to just unscrew. well when i started with the wrench i noticed it to be fairl tough to turn, well i look down at the nut, and the entire mount screw was coming off with it. i tryed and tryed to get the damn thing out but then just gave up, i ended up just usingthree boults to mount it and the stuck moutning one just sits threw the hole. seems to be no problem. but if n e one has a suggestion to getting it out just tell me. sorry for the long post
maroon 1998 mustang V6 auto. AM cai. Raxiom black headlights )
Senorjizzy is offline
Old 07-26-2009, 12:21 AM   #2
upton7's Avatar
upton7 is unknown around these parts
Re: installed my cai today
Explain the problem with the nut and bolt better and i'lll tell you exactly what to do.
upton7 is offline
Old 07-26-2009, 12:57 AM   #3
bloodyspirit058's Avatar
bloodyspirit058 is unknown around these parts
Send a message via MSN to bloodyspirit058
i left the screen on my maf, i don't think i was supposed to, i get a bit of a whistle from mine, doesn't hurt anything and i just have a deeper exhaust
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline
Old 07-26-2009, 01:23 PM   #4
CHILE10_STANG's Avatar
CHILE10_STANG is unknown around these parts
I took the screen off... Do you think it makes a difference?
IMPOSSIBLE IS NOTHING
2000 MUSTANG V6 - 18X9 AND 18X10 DEEP DISH BULLITT RIMS - RED CALIPER COVERS - CATTED PYPES X-PIPE- FLOWMASTER MUFFLERS- 3" STAINLESS STEEL TIPS - MOOORE TO COME!
CHILE10_STANG is offline
Old 07-26-2009, 04:55 PM   #5
Senior Member
19Delta is unknown around these parts
Negative, mine's off as well. Also, enjoy the whistle as you romp on it.
19Delta is offline
Old 07-26-2009, 05:37 PM   #6
upton7's Avatar
the screen blocks airflow it is better for you to take it off.
upton7 is offline
Old 07-27-2009, 07:26 AM   #7
well as i was unscrewing the nut to get the maf off, the bolt that the maf attached to was unscrewing with it, like the nut was on there too tight, or the bolt was too loose, ill try to take a pic of when i can. i think that all i need to do is just have someone or something hold the bolt end while i unscrew the nut.
Old 07-27-2009, 07:34 AM   #8
Terminator Owner
SpectorV is just getting started.
just relax take a break and look at it again later on, thats all thats needed sometimes... just to clear your head
SpectorV is offline
Old 07-27-2009, 01:13 PM   #9
sonicpony03 is unknown around these parts
^^^Yah true dat, sometimes it's just better to take a break...and come back to it after a few hours. You'll realize what you were doing wrong and feel silly about it once you solve the problem.
If I understand your problem correctly, it sounds like the bolt is rotating along with the nut, not allowing the nut to actually rotate off the thread of the bolt...if so, just use a socket wrench to hold the bolt head, and unscrew the nut with a wrench, it should twist off fairly easy. Let us know if that's the problem or if I'm missing it.
03 Sonic Blue Pony
Mods in Garage
Quit Lurking! Join Mustang Evolution Now!
http://www.mustangevolution.com/foru...eferrerid=7896
sonicpony03 is offline
Old 07-27-2009, 03:41 PM   #10
ik its not a big problem. i just hate knowing that its not rightly done ha. but sonic pony03, u got it right, i didnt think bout explainging it like that. sorry for the confusion, and thanks for the help guys.
Closed Thread
cai
I just installed a CAI 00BlackStang Pre-2005 V6 Mustang 14 08-18-2006 01:53 PM
CAI finally installed tedness Pictures and Videos 7 07-04-2005 08:54 PM
Rims on, fogs in, CAI installed *DUW* Stangthang Pictures and Videos 6 03-13-2005 07:35 PM
CAI Installed, but what the hell.. Seph The Bar 15 03-31-2004 01:07 AM
CAI installed... low idle problems... RedStang830 Pre-2005 V6 Mustang 16 08-03-2003 08:33 PM
02:28 PM
