help i screwed up on gears - Mustang Evolution
Old 07-30-2009, 07:06 PM   #1
2007STANG's Avatar
Region: West Virgina
I just finished installing 3.73 gears pulling out they feal great but when you let off the gas it sounds like the rear end is coming out on the jack stands it ran great no noise .005 back lash any ideas
Billet fuel door, Daiblo 91 Tune, Xenon ram air hood scoop, MAC performance direct fit headers, 3" 304 SS Dual exhaust, hood pin appearance kit, Red l.E.D. underbody lights, Boy Racer rear wing, Helix power tower plus Throttle body spacer, ventvisor deflector, Aeroform chin spoiler, SVT 18" 9.5 45/255 frount SVT 18" 9.5 40/285 rear trire , GTO rear blackout kit, OEM rear splash guards, Steeda CAI, 8.8 rear axle with 3.73.1 LSD, killer Glass Hose, Smoked Window Louvers by GT Styling 35% Tenting on rear and side windows.
2007STANG is offline   Reply With Quote
Old 07-30-2009, 07:52 PM   #2
upton7's Avatar
Re: help i screwed up on gears
first make sure the noise is coming from the gears
Old 07-30-2009, 07:55 PM   #3
2007STANG's Avatar
i have when i let off the gas it grinds and crunches sound real bad I'm starting to think i didn't get the crush sleve crushed enough ?????
Old 07-31-2009, 02:47 AM   #4
OsirisGuy's Avatar
I've never installed gears (let me say that first of all), but I was just going to say check the crush sleeve. I've heard that installing it incorrectly can cause many problems. What it came down to, I believe, is that you need a torque wrench and a breaker bar for it since under tightening it or over tightening it will ruin the whole install.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 07-31-2009, 08:07 AM   #5
they are not installed correctly, I personally dont know how to do it... but if all the parts are new (not used) then its installer error.
Old 07-31-2009, 05:34 PM   #6
2007STANG's Avatar
I took it to a dealer and in the back yard there was no way to get the croush coller compressed in the back yard i yanked my guts out and could not get it they said i did everything right except for having the *** to get it with out a three foot cheater learned my lesson i love doing things my self but on jacks in the yard is not the way to do it.
Old 07-31-2009, 06:01 PM   #7
Well, I give you credit for attempting to do it. I love working on my car, but no way in hell would I try and install that ****. How much did the dealer charge you afterwards?
Old 08-01-2009, 01:28 PM   #8
2007STANG's Avatar
waiting to find out
Old 08-01-2009, 02:16 PM   #9
hottcobra's Avatar
To set pinion preload you need an impact and an inch pounds with a needle not the click style. On a 7.5 rear it needs 25 inch pounds of rotational force.
You need to know what you are doing to install gears.
I will be doing a gear swap on my dads truck in a few weeks. I will have rob there to take pics and so a wright up on it.
Old 08-01-2009, 02:39 PM   #10
2007STANG's Avatar
the impack with my compressor with 125# air pressure wasn't enough
Old 08-03-2009, 09:12 AM   #11
also note on the newer 8.8's the range of tolerance is much tighter than on older 8.8s
Old 08-06-2009, 05:35 PM   #12
2007STANG's Avatar
well i'm back up and running " SWEET" learned a lot like a slinger looks like a shim and you can't crush the sleve in the back yard
Old 08-06-2009, 05:36 PM   #13
2007STANG's Avatar
i will have to work on wheel hop now any ideas ???
Old 08-08-2009, 12:55 AM   #14
2007STANG's Avatar
final cost $497 but i learned alot
Old 08-08-2009, 12:57 AM   #15
2007STANG's Avatar
Yea on the new 8.8 crush sleve the dealer said he uses a vice to start the crush sleve before he installs it
Old 08-08-2009, 10:11 AM   #16
wheel hop is fixed by locating the rear axle sideways and front to back firmly, so removing all the nasty bushings and eliminating the upper control arms... but most dont have to go that far to get good results. Lower control arms and stiffer springs may work good for you (with shocks valved for the springs)
Old 08-08-2009, 11:13 AM   #17
2007STANG's Avatar
ok i don't know if i understood that ?
Old 08-14-2009, 12:08 PM   #18
Herbstang's Avatar
glad you got the rear done !! Yeah without the right press your pretty much screwed those crush collar are a *****
Old 08-14-2009, 12:31 PM   #19
1998gt's Avatar
remember its gonna run differently on jack stands than it will on the ground
1998gt is offline   Reply With Quote
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
I got screwed....:( crazeflier07 Mustang Parts for Sale and Wanted 13 01-28-2007 06:24 PM
I get screwed over again... Tbird232ci The Bar 0 10-02-2005 09:50 PM
VW Owners Screwed bluemustang The Bar 2 07-25-2004 06:16 PM
the FBI screwed up Zim The Bar 3 05-29-2004 01:11 PM
10:30 PM
