How to achieve Low 14s in 1/4 mile? - Mustang Evolution
Old 05-01-2005, 12:08 AM   #1
I have a 99 v6 w/ cai, udp, x-calibrator chip, it's a five speed, 4.10 gears w/t-loc, short shifter and dual exhaust. What should I do now so that it will run low 14s in the drag strip. I prefer going N/A, Ported upper and lower intakes first? there's so many options.
ntc432 is offline   Reply With Quote
Old 05-01-2005, 12:53 AM   #2
97Stallion's Avatar
It's gonna take alot more. You definately need to get a cam, heads and intake package and maybe even a 4.2 stroker for the extra torque. That there should get you close too 300bhp and definately in the 14's
Living one day at a time!
Old 05-01-2005, 08:52 AM   #3
slvr2000stang's Avatar
You should be in the high 14's as is.
With a good launch & good driving.
I would say ported intakes might just do it.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 05-01-2005, 09:11 AM   #4
everything I have with a set of heads/cam/intake should put you in the 13.s with good 60s
Old 05-01-2005, 12:42 PM   #5
fastmustangs1's Avatar
Thumbs up
Cut some weight out of the stang. I have been doing weight reduction and it really helps the acceleration. Try that it is cheaper, take out spare tire, sound deadening and put in light weight race seats.
Matt
fastmustangs1 is offline   Reply With Quote
Old 05-01-2005, 12:45 PM   #6
Matt
thats not going to significantly help though. get H/C/I and most likely you will be in high 13's, with good driving.
Old 05-01-2005, 12:55 PM   #7
low 14s
Thanks guys, but one question, where should i get the ported and polished intakes, from the web? I see rpm-mustangs.com and super six motorsports, but there's so many options as to what else I should do, like the 65mm or 70mm throttle inlet, bolt post removal, divet welding, deleted egr ports, imrc delete and enlarged ports. Are any of these things really worth adding? I probably won't add a blower to my engine btw, so what do you guys think.
Old 05-01-2005, 01:04 PM   #8
rpm-mustangs.com all the way
Old 05-01-2005, 01:16 PM   #9
rpm
ok..but should I do all those extra things for the intake that i mentioned above?
Old 05-01-2005, 01:18 PM   #10
port the heads intakes and get a cam.Mik the owner of rpm will tell you what will be the best mods to go with the HCI swap.
Old 05-01-2005, 02:02 PM   #11
Kelly's Avatar
get everything I have minus the TC obviously and you will be there easy. I run low 14s and I'm an automatic.
02 Mustang v6 auto:
4.10 t-lock
Xcal2 tuned by Justin
3200 PI stall
FMS Aluminum DS
RPM P&P upper and lower
RPM GT TB
RPM 207/207 cam
DMM denscharger
GT Takeoffs w/ X-pipe, spintech mufflers, hi flows
MAC ceramic coated LT's
ASP UD crank
13.95 @ 98.15
Kelly is offline   Reply With Quote
Old 05-01-2005, 04:34 PM   #12
RPM & Super six are both great places to order from.
Contact them both, explain your goals for the car, and make an informed decision from their responses.
They are the experts & will give you an honest reply.
I have dealt with both.
2000 Vert 4R70W
Old 05-07-2005, 11:46 PM   #13
hit the track
Well I just got back from the drag, very disappointed in my times. I am pretty sure it had to do with my crappy launches cuz I bogged and didn't catch traction for a good second all the time. Anyways, heres what I got:
BTW: these are my two best times out of the six times.
R/T: 0.535 0.295
60: 2.331 2.221
1/8: 10.208 10.208
MPH: 70.73 70.25
1000: 13.207 13.269
1/4: 15.744 15.807
MPH: 85.96 89.48
I was shifting at about red line most of the time. Anyone give me some tips?
1999 v6 MUSTANG
Current Mods:
CAI (Mac Straight Shot)
ASP UDP 25%
Steeda Tri-Ax Short Shifter
GT Dual Exhaust with OG Flowmaster 40s
X-Calibrator Chip
4.10 Gears and T-Loc
Next Mods:
Mach 1 Rims & Tires
Old 05-08-2005, 01:15 AM   #14
Kiljosh's Avatar
What were you launching at? Btw, nice RT!
Old 05-08-2005, 07:41 AM   #15
Regarding track numbers.
A huge factor in how you run is:
1. Track conditions.
2. Weather conditions. If the temp or Humidity are higher or the Baro pressure lower your times will suffer.
2000 Vert 4R70W
Old 05-08-2005, 07:44 AM   #16
R/T: 0.535 0.295
60: 2.331 2.221
1/8: 10.208 10.208
MPH: 70.73 70.25
1000: 13.207 13.269
1/4: 15.744 15.807
MPH: 85.96 89.48
Mickey T E.T Streets on 15 in rims
GT-Eater is offline   Reply With Quote
Old 05-11-2005, 10:28 PM   #17
Send a message via AIM to spadez81
Can someone tell me how to achieve 300hp in a V6. Mine is an 04 with a 5speed and I'm trying to find the right combination to achieve the 300 mark, and will that give me a good et on the track?
Spade Has Arrived !!!!!
'02 Black GT 5-spd.(Mods coming shortly)
spadez81 is offline   Reply With Quote
Old 05-11-2005, 10:34 PM   #18
4.2L stroker kit.
Old 05-11-2005, 11:14 PM   #19
I liek gramer
WhiteStang99's Avatar
Originally Posted by n8r
4.2L stroker kit.
and a Mustang to put it in.
Old 05-12-2005, 07:36 AM   #20
Question for you.
the 300hp mark you speak of is that at the wheels or the crank?
2000 Vert 4R70W
Looking for a set of low low ratio 7.5" gears PureVenom Pre-2005 V6 Mustang 4 08-13-2008 05:15 PM
03 Gt Pi Heads And Cams!!!! Low Miles/low Price alwaysthefinest Mustang Parts for Sale and Wanted 1 05-24-2007 06:17 PM
03:29 AM
