aod on a 289 - Mustang Evolution
Old 05-02-2005, 10:25 PM   #1
aod on a 289
anyone know what it will take to put an aod on a 289, its for a friend who has a 66 mustang coupe, but he is tired of the three speed so he wants to see if he can swap it to an aod. anyonw know what it takes to do so?
Old 05-03-2005, 10:29 AM   #2
Bane-'s Avatar
keep it 3spd (auto or manual?), its fun if anything maybe a different bell housing would be needed for it to bolt up. 289/302/351w same block so maybe he should look into that.
Old 05-03-2005, 02:04 PM   #3
Tbird232ci's Avatar
the tranny will bolt up, thats not an issue
the hard part will be the crossmember, the shifter linkages, and the throttle valve cable/linkage
Old 05-03-2005, 04:46 PM   #4
so getting one from a 302 would work? cool then. are there any places that sell the cross member for that, the TV cable and shifter linkage would have to be modded but we can fab something up. so the only real problem is the crossmember?
Old 05-03-2005, 05:08 PM   #5
www.shockley.net/holley-aod.asp
that might help
Old 05-03-2005, 07:19 PM   #6
fast64's Avatar
he should do a t-5 swap! 5 gears w/ cable clutch > 3 gears with z-bar. pretty easy to do also
GO BRAVES
Old 05-03-2005, 10:24 PM   #7
he wants an auto
Old 05-11-2005, 09:18 PM   #8
tire's Avatar
Send a message via AIM to tire
Originally Posted by 232stang
he wants an auto
then tell him to get a grocery getter!
but yes, as the others have said... fitment isn't the issue, it's the finishing that may be a PITA. make sure the place where the new brace bolts up is solid and not rusted... or he'll end up dragging his tranny down the highway later.
austin
tire is offline   Reply With Quote
Old 05-11-2005, 10:31 PM   #9
well we found found a bunch of info already, stangnet helpe out there.
AOD to T5 Swap Thread Kiljosh Pre-2005 V6 Mustang 0 10-14-2008 05:03 PM
90gt aod help Xx_1990GT_xX 1979-1995 Mustang GT 10 08-30-2008 10:50 AM
89 AOD question bob2231 1979-1995 Mustang GT 0 04-12-2008 08:12 PM
AOD Questions GizmosMustang 1979-1995 Mustang GT 5 02-09-2006 10:18 AM
09:46 AM
