Wiring harness or lock/window assembly? - Mustang Evolution
Old 08-03-2009, 12:25 AM   #1
2000 Mustang V6. The driver side door works fine. The passenger side window wont roll up/down and the door lock will not engage unless pushing down manually. The passenger side lock switch will lock/unlock driver side though. I have the door panel removed. So, Im wondering is it the assembly or wiring harness and how do I fix either one. I have a spare assembly to replace the old but cant remove the 3 screws on outside of door because theyre stripped. Any suggestions appreciated!!
rachl1999 is offline   Reply With Quote
Old 08-03-2009, 10:55 PM   #2
Re: Wiring harness or lock/window assembly?
If the switch on the passenger door is actuating the drivers side door lock, it sounds like its not the switch assembly that is borked I'd get to checking the wiring. If the screws are stripped it sounds like someone has been screwing around in there before, perhaps they pulled something loose?
ThaWill is offline   Reply With Quote
Old 08-03-2009, 11:55 PM   #3
When I purchased the vehicle the passenger side window/lock didnt work but a few months later started working again. I just bought a screw/bolt extractor and have yet to use it to see if its the assembly. If I find out its not, could you suggest how I check the wiring?
Old 08-04-2009, 01:36 AM   #4
A Multimeter.
19Delta is offline   Reply With Quote
fox body alternator to classic mustang wiring harness ericgreen29 Classic Mustangs 0 07-18-2009 07:35 PM
1995 Wiring Harness Farah51 1979-1995 Mustang GT 1 03-16-2009 03:56 PM
Eclipse CD3100 + wiring harness & double din adapter jimmy_beaner Mustang Parts for Sale and Wanted 2 04-07-2008 06:56 PM
what wiring harness Zim Mustang Audio & Video 9 01-10-2006 08:37 AM
Do you think its worth it - modify wiring harness myself or pay a pro????? fast64 The Bar 8 11-09-2004 09:32 PM
03:04 AM
