Need Help - Mustang Evolution
Old 05-07-2005, 05:33 PM   #1
Need Help
Ok i Have a 2002 Ford Mustang and yesterday i had to go down a dirt road to get to school and it had a few pot holes that i had to go through well it just rained about at the end i slide sideways awhile and about hit a pole but didnt. Well now my car shakes kinda bad around 60-70 and does it really bad when i let off the gas. What could it be????
graystangguy06 is offline   Reply With Quote
Old 05-07-2005, 05:36 PM   #2
the best place to start is checking the balance of the wheels. Sounds to me that you warped a rim or threw a weight off of the rim. Take the car to a shop where they balance tires and get them to check the wheel(s) If you know which one you hit with the hole its easy to know which one to check otherwise you got to check all of them. i bet the problem is in the rims/tires being out of balance/warped.
Old 05-07-2005, 05:38 PM   #3
make sure to mention that the wheels may be warped so they can check for that as they check the balanceing of the wheels.
Old 05-07-2005, 05:41 PM   #4
19ClearCobra96's Avatar
Region: Nebraska
Send a message via AIM to 19ClearCobra96 Send a message via MSN to 19ClearCobra96
worse case scenario I would guess a bent axle. but Spector's diagnosis sounds about right
19ClearCobra96 is offline   Reply With Quote
Old 05-07-2005, 05:46 PM   #5
Thanks do you think i should just take it to the ford dealership and have them check everything out??
Old 05-07-2005, 06:03 PM   #6
You can... they are known to charge to much though. Was it the front or rear? If its the rear you may have a warped axle as stated above. In any since the parts are not to expensive. I will sell you all 4 stock 15 inch rims for 150 with tires on em lol an axle for your car is 76 bucks... so its not a huge deal. Try not to drive much with it, if it ONLY does it at an XX mph range then its most definatly a wheel out of balance, if it gets worse as you drive faster and faster it could still be a wheel out of balance or something warped. Ford can fix it but may charge to much...
Get a diagnosis and let us know what they say.
Old 05-07-2005, 06:18 PM   #7
I liek gramer
WhiteStang99's Avatar
I'd take it somewhere other than Ford, but I was thinking the same thing Spector was. It's probably a warped wheel.
Old 05-07-2005, 06:25 PM   #8
I took a chunk out of one of my old wheels on my 97 v6 hit some oil spun around and went up on a median... cost me 160 for a new rim... what a rip off, I was a mustang NOOBIE back then (dont spread it around though)
11:46 PM
