installing shocks and struts - Mustang Evolution
Old 05-10-2005, 11:53 PM   #1
so im gonna be installing shocks and struts pretty soon i just ordered them (tokicos) so i know how to install them but i just have a question. does the camber plate have to be unbolted, i would not think so but im not sure. i would think just taking off the top nut with a crow foot wrench and a screw driver to hold the shaft.
And yeah i have air tools and a lift that i can use.
Old 05-10-2005, 11:59 PM   #2
jimmy_beaner's Avatar
Region: Iowa
I can't help ya' out... and Brent's the only other one on
Old 05-11-2005, 12:02 AM   #3
this question is real simple, i dont think i will have to i just want to know, cause if i do i make sure to align my car right after (my old boss has an alignment rack i can use. its quite easy too)
Old 05-11-2005, 12:03 AM   #4
Region: Iowa
yeah, I still don't know anything about it.... also, look at my post about "tonight" in parking section
Old 05-11-2005, 06:19 PM   #5
i was reading through past post and found out i was right the camber plate does not have to be taken off.
i wonder if the front struts are gonna give me problems since i got 87-93 struts because they are shorter and i have a 1.5 inch drop. but the stang suspension guy said 87-93 front struts are what i need for my drop.
Old 05-11-2005, 08:50 PM   #6
Tbird232ci's Avatar
just use an impact gun to get the nut off of the strut
as for using the fox stang struts, dont do it, the shocks and struts also limit your suspensions downward travel, and by using those shocks and struts, your more likely to have problems with dips in the road
Old 05-11-2005, 09:17 PM   #7
Sorry missed this one. They do not have to come off like you said.
Old 05-11-2005, 09:25 PM   #8
Ponycarman's Avatar
You don;t ahave to take them off and you also don;t have to hold the strut with a screwdriver if you loosen up the nut before you ttake the wieght off the front tires.
I did a whole write up with pictures that Brent never put in the how to section, thanks Brent.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 05-11-2005, 09:46 PM   #9
Steve
I lost the write up in one of my computer reformats and forogt about it. If you wish to send it to me again I will put it up I promise.
Not done intentionally.
Old 05-11-2005, 10:12 PM   #10
tire's Avatar
Send a message via AIM to tire
To answer your question, a screwdriver won't do it. I had a hell of a time with my buddy's 2000 v6... we ended up having to buy a 20 dollar tool from Autozone or the like to finally get that front shock from rotating. (Not just the center part rotates, its the whole thing, and it's a PITA without the tool)
Don't forget to get your car aligned after the install, good luck.
austin
tire is offline   Reply With Quote
Old 05-11-2005, 11:37 PM   #11
um a screwdriver will do it. i used that when i installed the springs. the reason i use this method is bcause i always torque stuff on my car to specs. and a air gun does not torque to spec but by holding the shaft with a screw driver and using a crow foot wrench i can use the torque wrench to tighten it. thanks so the plates dont have to be unbolted cool that will save me some time.
Old 05-11-2005, 11:38 PM   #12
which front struts did josh give you?
Old 05-13-2005, 09:51 PM   #13
i got them today
too bad i wont be able to install them till next saturday.
Old 05-14-2005, 01:13 AM   #14
i was surprised to find that they came with hardware, im thinking of using my stock hardware, if the hard ware that comes with the tokicos are not grade 8. are they grade 8? i could not believe how hard it was to compress these as opposed to my stockers.
Old 05-14-2005, 04:45 AM   #15
Ponycarman's Avatar
I figured something like that.
It's at home, I'm at work. Monday if I remember I'll send it.
Steve
1996 Mustang
1965 Barracuda
Struts and Shocks xcxm049 Pre-2005 V6 Mustang 11 03-05-2010 01:59 PM
shocks/struts Sublime782 Pre-2005 V6 Mustang 15 05-15-2007 02:06 PM
shocks and struts all8280bcc 1996-2004 Mustang GT 8 03-01-2007 01:49 PM
Shocks Struts megax29 Pre-2005 V6 Mustang 11 07-12-2006 10:34 PM
Shocks..struts Exit_In_Red Pre-2005 V6 Mustang 6 12-01-2004 11:33 PM
04:22 PM
