Temperature problems - Mustang Evolution
Old 08-12-2009, 01:06 AM   #1
tvsr's Avatar
Region: Nevada
Unhappy Temperature problems
I've fixed up my 1999 mustang really good since I bought 4 months ago. It was having problems with the 6th cylinder missfiring and changed the spark plugs with new factory set motorcraft plugs but now there's something wrong with the temerature. When I turn it on it doesn't heat up the needle doesn't even move even after 10 minutes letting it alone it won't go to the proper temperature, then when I drive it it starts heating up BAD. It overheats in about 15 minutes. There's coolant and the radiator has water in the cap but it still overheats.?? Does anybody know why? I was thinking I might need to replace the radiator cap as I've heard from another source but I don't think it's that.
tvsr is offline   Reply With Quote
Old 08-12-2009, 01:24 AM   #2
tvsr's Avatar
Region: Nevada
Re: Temperature problems
after the spark plug change the car was good to go then a few days later that's when the temperature problems came up
Old 08-12-2009, 01:37 PM   #3
check your thermostat and make sure your radiator and grille aren't clogged/blocked by anything like leaves
ThaWill is offline   Reply With Quote
Temperature sensor? falconplayer79 Pre-2005 V6 Mustang 10 12-24-2008 07:23 PM
10:34 PM
