intake manifolds - Mustang Evolution
Old 05-16-2005, 08:19 AM   #1
Exclamation intake manifolds
If i got a 99-04 3.8 Ported Upper Intake Manifold from rpm could i still get it powdercoated or painted. Also can i just get a upper intake and keep the stock lower manifold
coolstang is offline   Reply With Quote
Old 05-16-2005, 08:44 AM   #2
slvr2000stang's Avatar
Yes you can do just the upper intake.
Yes you can get it powder coated.
The gains from just an upper will be minimal since there are still restrictions with the stock lower & heads. But it it a start.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 05-16-2005, 08:46 AM   #3
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
^word. you can get it powdercoated. blue is a good color
but if you only get the upper, you won't see much in gains, the lower is too restrictive. it'll be a bottleneck effect
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 05-16-2005, 09:38 AM   #4
Thank you guys
Old 05-16-2005, 02:51 PM   #5
if i got rpm ported and polished upper and lower intakes with 65mm throttle body and a underdrive pulley. How much hp should i expect
Old 05-16-2005, 07:43 PM   #6
dark's Avatar
a bit more. but don't bother with a TB, it's not worth it unless you're pushing some volume... get heads and/or cam instead
leaky manifolds dshultz88 Pre-2005 V6 Mustang 1 10-19-2007 07:29 AM
New SOHC Intake Manifolds JROC 1996-2004 Mustang GT 4 10-04-2006 12:11 PM
Pictures of polished intake manifolds TheSarge Mustang Audio & Video 11 09-14-2003 07:43 PM
01:05 PM
