3.9??? - Mustang Evolution
Old 08-13-2009, 11:07 AM   #1
Send a message via AIM to LindsayCaitlin
3.9???
I have a 2004 3.9 v6 automatic and I've been wanting to get an Exhaust System/Headers/Intake/Etc.. Every website I go to for mustang parts sells them for the "1999-2004 3.8L v6" Does anyone know if I can use performance parts such as these on my 3.9? I can't find any place that specifically makes things for that engine. Thanks!
~Lindsay
LindsayCaitlin is offline   Reply With Quote
Old 08-13-2009, 11:24 AM   #2
Re: 3.9???
The 3.9 and the 3.8 are basically the same motor. Anything that will fit a 3.8 will fit a 3.9.
19Delta is offline   Reply With Quote
Old 08-13-2009, 12:32 PM   #3
Re: 3.9???
yup the difference is some left over van parts like the crank and rods that slightly bump it to 3.9L.
I dont know of anything that is not compatible modification wise from the 3.8L engine to the 3.9L engine.
Old 08-13-2009, 03:40 PM   #4
a3705872's Avatar
Re: 3.9???
Here is a fun fact also, according to Auto zone's website, 80% of 2004 mustangs have the 3.9 while the other 20% have the 3.8. I am one of the 20% who got the 3.8
a3705872 is offline   Reply With Quote
Old 08-13-2009, 03:42 PM   #5
Re: 3.9???
While autozone may be correct in this stat...they are definitely the last place I would trust for facts. lol
Old 08-13-2009, 11:03 PM   #6
mystanghurts04's Avatar
Re: 3.9???
yea, i have an 04 3.9l, and all the parts i got for it sofar, was for the 3.8, and there all the same, but the only thing u should watch out for is if u get a tuner, they cant use the same tune.
mystanghurts04 is offline   Reply With Quote
Old 08-14-2009, 08:07 AM   #7
Re: 3.9???
what kind of parts have you put on your 3.9 so far? like the basic headers and stuff like that?
~ Lindsayy =)
Old 08-14-2009, 08:13 AM   #8
Re: 3.9???
headers are nearly worthless on the V6. You basically do a cold air intake, under drive pulley, and exhaust (exhaust first for sound, looks, and performance) and such finish off with a tune (hand held so you can modify later for different things)
After the basic things you can do rear end gears and a positive traction tlok unit (both wheel spin vs one wheel spin stock). This is the BEST bang for the buck but hurts gas mileage and can be costly (especially if not installed correctly).
For looks/handling lowering with a set of nice wheels/tires makes ALL the difference.
I owned a 97 3.8L v6 mustang and a 01 3.8L v6 mustang before my 03, there are tons of things to do and they have tons of potential, but the basic bolt ons will not do much of anything sadly... but every little bit helps.
Old 08-14-2009, 08:20 AM   #9
Re: 3.9???
i have mac H pipe, flowmaster 40s, cold air intake, and an intake mainifold spacer.
Old 08-14-2009, 08:20 AM   #10
Herbstang's Avatar
Re: 3.9???
I hear ya !!
Old 08-14-2009, 09:30 AM   #11
Re: 3.9???
only problem is my car is an automatic 3.9L, so it's basically crippled by that god forsaken transmission.. anyone know of anything i could do to improve it without actually getting a new transmission?
~ Lindsayy =)
Old 08-14-2009, 09:43 AM   #12
Re: 3.9???
A custom tune would wake it up tremendously. It will change your shift points and improve the shift pressures and make it feel like a completely different car.
Old 08-14-2009, 09:48 AM   #13
Re: 3.9???
would the transmission as it is right now be able to handle any modding?
~ Lindsayy =)
Old 08-14-2009, 09:50 AM   #14
Re: 3.9???
Absolutely. Kyle that used to be on here alot had an 04 auto. Had a very aggressive custom tune, standard bolt ons (under drive pulley, CAI, etc). His car was fine. Keep in mind, you have the same transmission they put into the auto MACH 1's and GT's as well. You are good to go with your car before you start endangering the trans.
Old 08-14-2009, 10:23 AM   #15
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: 3.9???
Your transmission will be fine. I'm around 350 to the wheels on a stock auto with nothing but a secondary inline tranny cooler.
DarkShadow is offline   Reply With Quote
Old 08-14-2009, 10:46 AM   #16
Herbstang's Avatar
Re: 3.9???
A tune will wake that 3.9 up your only a hour or so away from VMP tuning Justin is the demi-god when it comes to tuning v6 mustangs
VMP Tuning - Buy Ford SCT & GM Custom Handheld Flash Tuners Performance Economy Towing
Old 08-15-2009, 09:26 AM   #17
Re: 3.9???
So what happens if i get my car tuned and then continue modding my car? Will I have to get it tuned again? I checked out that VMP Tuning site, they have some cool stuff.
~ Lindsayy =)
Old 08-15-2009, 09:56 AM   #18
Re: 3.9???
It depends on the mods you add. If you change out things like your MAF, heads, maybe a ported intake...then yeah, you would need an updated. IF you're just talking UD pulleys, CAI, mufflers, and things like that, then no, you won't.
08:20 AM
