How hard to grind off powdercoating on MM sub frames? - Mustang Evolution
Old 05-18-2005, 05:44 PM   #1
I want to get a set of MM's full length subframe connectors in powdercoated black to prevent rust but you have to remove the powdercoat where you weld.... how hard is it to grind it off with air tools?
Old 05-19-2005, 02:39 PM   #2
fastmustangs1's Avatar
Shouldn't be that hard just grind it off.
Matt
fastmustangs1 is offline   Reply With Quote
Old 05-19-2005, 02:52 PM   #3
Danger Dude's Avatar
It comes off pretty easy with scotch brite wheels. I usually just bead blast stuff though.
Old 05-19-2005, 05:20 PM   #4
just take a grinder to its it should not be too bad, hey maybey even try brake fluid that **** kills powder coat and paint.
2008 3rd gear grind when cold gotmach Pre-2005 V6 Mustang 16 02-06-2009 07:07 AM
reverse gear grind chris098 1996-2004 Mustang GT 8 01-21-2008 09:49 PM
switching top and frames at the same time flysure1 1979-1995 Mustang GT 1 01-14-2008 12:04 PM
clutch grind ChickStang02 1996-2004 Mustang GT 21 03-24-2007 05:20 AM
intake porting and powdercoating intake(RGR) 232SCstang Pre-2005 V6 Mustang 7 01-11-2004 08:41 AM
08:58 PM
