*sigh* I've about had it, at wits end! - Mustang Evolution
Old 08-16-2009, 09:20 PM   #1
rinfield2004's Avatar
So, heres the deal. 2wks ago, I installed a pair of BBK titanium colored valve covers. They look amazing! Set the whole motor off! Install itself was quick and easy.
So, had an oil leak on the driver side, fixed by using gasket maker. Ok? That problem was alieviated. Next issue is the "exhuast leak-like sound" thats coming from the passenger side of the motor. Bear in mind that I'm using the BBK valve cover gasket that they supplied.
Over the past 2 wks I've combed and touched every exhuast component on that side. Went as far as removed the header from the head. removed old gasket, put a new one on. cleaned BOTH surfaces. rethreaded and torqued the exhuast pipe end of the header. EGR is threaded and bottomed out correctly. *sigh*...............................
I'm STILL getting the exhuast leak-like sound. I'm about at my wits end. What could it possibly be?! Where else could it possibly coming from?! Could the rubber BBK gasket have anything to do with it? I'm anticipant to hear what you have to say.
rinfield2004 is offline   Reply With Quote
Old 08-16-2009, 09:27 PM   #2
redcobravert's Avatar
Re: *sigh* I've about had it, at wits end!
you should be able to feel an exhaust leak
redcobravert is offline   Reply With Quote
Old 08-16-2009, 09:35 PM   #3
if its not the header(either end), EGR, nor intake. then where?
Old 08-16-2009, 10:23 PM   #4
check underneath the car for leaks
Old 08-16-2009, 10:50 PM   #5
upton7's Avatar
don't just listen for leaks go by every place where a pipe connects and feel the exhuast leak with your hands thats the only way to know
Old 08-17-2009, 01:26 AM   #6
MonteCitan's Avatar
Are you sure it's an exhaust leak? Without hearing the car, just throwing ideas out there - maybe valve cover doesn't have quite enough clearance and a rocker arm is hitting, or some valve covers have oil control shields in place which one might be misaligned or too close
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 08-17-2009, 09:14 AM   #7
I'm 80-90% sure its not an exhuast leak. Its "exhuast leak-LIKE" sound. Its a noise that sounds LIKE an exhuast leak thats throwing me of and pissing me off. I'm not getting any noise from the driver side. Only passenger. I looked underneath the BBK valve covers and wasn't any place to relocate the OEM oil control shields(I saw those, I know what you're referring to). I wasn't getting the sound BEFORE the installation, only after. With that said, I only touched the valve cover, throttle body, and EGR to install the valve cover.
Just trying to give you as much accurate, detailed, information as possible.
BTW- I have an 01 Mustang V6 (3.8) Supercharged.
Old 08-17-2009, 09:23 AM   #8
you should take a video and post it up that might help us
Old 08-17-2009, 09:34 AM   #9
hottcobra's Avatar
with the engine running put your hand on the valve cover and see if you can feel something hitting the inside of the valve cover.
If the noise started right after the valve cover install it has to be something done with the install.
Old 08-21-2009, 04:29 PM   #10
SaleenFiend's Avatar
Let somebody with experience handling this issues deal with it becuase obviously you can't seem to figure it out.
Old 08-30-2009, 01:30 AM   #11
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Come on now, that doesn't help.
If putting your hand on the valve cover doesn't help you find anything, get yourself a 1/2" piece of rubber hose about 2 feet long or so, and use it as a stethoscope. Put one end to your ear and move the other around the engine bay near the motor. When the sound gets a lot louder through the hose you've found your noise.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 08-30-2009, 08:23 AM   #12
bbunt302's Avatar
Sounds like the valve covers don't have enough clearance for the rockers. Do you have aftermarket roller rockers by chance?
Scary stuff.
Old 09-01-2009, 07:21 AM   #13
Not trying to be a dick, but sometimes it's just best. Obviously he is having a hard time even narrowing down the issue so it may be best for somebody else to give it a try, instead of taking wild guesses from the internet
Old 09-01-2009, 03:17 PM   #14
Ninethourpm's Avatar
Sounds like a painfull way to find it!!!!!!!
2000 silver 3.8 5 speed,smoke tint,cold air intake,MAC Long tubes, MAC Catted H,MAC GT catback, SCT Livewire w/ Bamachips tune,
17x8Fr 17x9Rr Bullit Wheels More to come......
96 honda magna vf750, K&N, Vance and Hines pipes Rejetted carbs
Ninethourpm is offline   Reply With Quote
Old 09-01-2009, 09:28 PM   #15
LilRoush's Avatar
BBK valve covers suck. Ditch the bling and go back to stock... then see if you still have issues.
~Matt
2000 Roush #5004 M112'd V6
1970 Mach 1 351W 5 speed swap
2001 Explorer Sport 4.0L
LilRoush is offline   Reply With Quote
Old 09-02-2009, 07:05 AM   #16
While your Avatar is cool... I don't like it. BTW (out of curiousity) what numbers are you posting?
Old 09-02-2009, 08:00 AM   #17
LilRoush's Avatar
I love my "V8 killer" stock blower pulley, smaller one said "Ferrari Killer". Too many people too a two second look at the motor, and assumed it was an 03/04 4V swap.
Makes zero right now, I pulled the car apart and put it into storage last Feb.
At it's prime it was a fully built 4.3L, 2.78" pulley on the ported M112, 10% OD crank pulley to spin it faster with a triple digit NX wet shot for good measure. Enough to handle pretty much any V8 Mustang who liked to poke fun at the 'girlie V6 Mustang'.
~Matt
Old 09-02-2009, 08:21 AM   #18
What kind of numbers were you pushing? E.T.s? I am interested to know what the 6ers are making.
Old 09-02-2009, 03:45 PM   #19
What the 6ers are makeing I've heard there are a few Twin turbo setups putting out 700 HP. I have not seen the dynos, so don't ask.
* Ford V6 Mustang Dyno Graph Database *
The FASTEST V6 Fords!
Old 09-02-2009, 04:10 PM   #20
LilRoush's Avatar
Since we're taking this off topic...
ETs? You must think everyone drag races. Not true, I don't drag the car. It's an open track car.
Yes, there are a several sixers pushing over 700 rwhp now. The highest (that is active in the world of internet forums) is right around 900 flywheel. Many of those are the pushrod 3.8L/4.2L cars, but there are seveal high hp 4.0L SOHC ponies out there as well.
~Matt
Old 09-03-2009, 08:03 AM   #21
the most N/A ive heard of is around 250rwhp or so stroked~ I am sure that can be pushed higher and probably has since I heard last.
Old 09-07-2009, 01:25 AM   #22
Lol I love how guys get side tracked and chase rabbits on here lol.......sorry I haven't been on to get back at you guys......
Got the problem fixed. Ended up sayin,"Ef it" and buying a whole new set of BBK shortie headers, gaskets and all. Problem alieviated. In addition to fixing this, I also fixed my boost leak that I had, as a result, picked up an additional 2lbs of boost.
Now, my tunes all kinds of outta wack. trips and stumbles just and only under intial goose of the throttle....it then smoothens out. Heading to memphis to my tuner the 14th to fix that.
Old 09-13-2009, 07:19 PM   #23
stangaroo's Avatar
I'm huntin wabbits
stangaroo is offline   Reply With Quote
*sigh* Mach 460 took a dump jimmy_beaner Mustang Audio & Video 0 05-20-2007 01:05 PM
*sigh* DarkShadow The Bar 15 10-04-2006 11:30 PM
I think the end is near PureVenom The Bar 24 07-07-2006 09:21 PM
*sigh* dumb sorority *****es.........i hope they never change Kyle The Bar 13 10-02-2005 03:30 PM
sigh stupid not knowing what their own car is Bane- The Bar 6 09-08-2004 07:18 PM
05:11 PM
