Water Pump Bolts - Mustang Evolution
Old 08-18-2009, 01:46 AM   #1
Water Pump Bolts
I have a weird situation with 4 water pump bolts/studs. Those are the ones that go through the cam cover into the engine block. Two of them came out, one came out halfway and the 4th one did not come out at all. How the heck do I get them back in?
I'm afraid of breaking off the one that came out halfway, but I guess I need to screw it back in somehow?
Any suggestions?
audi_b is offline   Reply With Quote
Old 08-20-2009, 03:22 AM   #2
2007STANG's Avatar
Region: West Virgina
Re: Water Pump Bolts
The one that part way out i would take all the way out and replace if the threads are bad if not put it back in but at least look at
Billet fuel door, Daiblo 91 Tune, Xenon ram air hood scoop, MAC performance direct fit headers, 3" 304 SS Dual exhaust, hood pin appearance kit, Red l.E.D. underbody lights, Boy Racer rear wing, Helix power tower plus Throttle body spacer, ventvisor deflector, Aeroform chin spoiler, SVT 18" 9.5 45/255 frount SVT 18" 9.5 40/285 rear trire , GTO rear blackout kit, OEM rear splash guards, Steeda CAI, 8.8 rear axle with 3.73.1 LSD, killer Glass Hose, Smoked Window Louvers by GT Styling 35% Tenting on rear and side windows.
2007STANG is offline   Reply With Quote
Old 08-21-2009, 02:16 PM   #3
SaleenFiend's Avatar
Well if the bolt won't come out it could mean one of two things. It seized up in there or (this sounds very possible) somebody crossthreaded and lock-tite'd the bolts in the water pump before. I would remove everything, inspect the threads of the holes and bolts. I'm not sure if those bolt holes can be re-tapped or not but you may have to tap them with an oversize die bolt.
Old 08-30-2009, 01:34 AM   #4
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
The studs that came out sound like they are fine. The one that stayed in should be fine. If the other one cam part way out and then the nut on the end unscrewed instead of the rest of the stud coming out, I'd say you should just screw the stud back in and reinstall the nut. Two nuts jammed together on the end of the stud is a pretty good way to get it screwed back in.
If it's really hard to screw in or out though, you may have a problem and a tap and die set may be needed.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Changing Water Pump wvstang5.0ho 1979-1995 Mustang GT 9 07-13-2008 09:45 PM
water pump ? jumpman1203 Pre-2005 V6 Mustang 0 10-16-2006 12:25 AM
Water pump took a dump KyleUSAF Pre-2005 V6 Mustang 16 01-25-2006 01:35 PM
electric water pump? widowvirgin Pre-2005 V6 Mustang 15 07-01-2004 03:30 PM
water pump replacement Ponycarman Pre-2005 V6 Mustang 3 01-16-2004 10:26 PM
11:09 PM
