Manual Tranny that will hold about 400 to the wheels.... - Mustang Evolution
Old 05-21-2005, 07:45 PM   #1
If I can get a tranny that will hold about that much hp without any fear of it breaking AND a spec stage 2 clutch AND everything I need for the swap from my auto for about 1400 dollars I will do the swap.
What are we talking price wise for jus tthe tranny that will meet the requirements above?
Old 05-21-2005, 07:48 PM   #2
http://www.astroperformance.com/
g-force t-5
get a 26 spline clutch The G Force uses a 26 spline input shaft.
get a 26 spline mcleod setup
Old 05-21-2005, 07:49 PM   #3
but your computer will prolly have to be altered with a chip because of the tranny swap i believe. and a bunch of little parts.
Old 05-21-2005, 08:01 PM   #4
lol that transmission is 200 dollars more than my total budget for the entire swap so it looks like brent stays with a beefed up Auto.
Old 05-21-2005, 08:05 PM   #5
get a promotion tranny from there thats the tranny gt eater is running.
Old 05-21-2005, 10:16 PM   #6
Bane-'s Avatar
beefed up autos are
my c4 can handle 750-800hp, not saying im even going to come close to that but its a nice lil comfort barrier
(and im not trying to start a auto vs manual debate again...its dead and over)
Old 05-22-2005, 12:30 AM   #7
Originally Posted by Bane-
beefed up autos are
I know but I drove my managers Formula Firefird today w/ a 6 speed and I want a Manual now
Old 05-22-2005, 01:13 AM   #8
you going to be putting money into a tranny, yours will not hold up long to the new power plan unless you really take it easy on it.
A stock GOOD condition t5 will take ALOT of abuse and will be fine unless you take it to the track ALOT, if you want added security you will have to step it up... Gforce makes a good tranny.
Bens tranny is taking 300rwhp or more and its got a TON of miles 120k or so its still pretty good so they can take it IF you get a good one and not a POS.
Old 05-22-2005, 05:21 AM   #9
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
your best bet is probably www.astroperformance.com
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 05-22-2005, 05:27 AM   #10
Ponycarman's Avatar
The stock A833 can handle 400+ HP not matter how hard you beat on it.
But it is an old school 4 speed made by Chrysler. They did make a few Ford and Chevy specific applications. I got three of them in the store room, all MoPar versions though. It is, however, a real manual that is not as buttery smooth to shift as today's weenie transmissions, but it is very, very stout. It's also all cast iron, except for the late OD versions. It is a side shifter, too. Probably be a real bear to put into a later Stang though.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 05-22-2005, 10:45 AM   #11
dont mess with that, get a good 99+ t-5 and use a tail shaft from an older one to go back to speedo gear, get an older one with a gear already in it, get a tremec tko (go for 1400~), or a Gforce t5 (more than your budget i do belive but maybe not)
Old 05-22-2005, 01:32 PM   #12
Too much money and trouble for the swap. I'll just spend 1300-1400 and get the same thing out of my auto.
Old 05-31-2005, 10:46 AM   #13
will the tremec t56 6-speed from the trans ams, corvettes, vipers etc. fit in our cars. I've actually been considering doing a manual swap but if i do i want a 6 speed
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline   Reply With Quote
Old 05-31-2005, 10:55 AM   #14
the only 6 speed worth even looking at is the viper spec. well unless you like to autox....
Old 05-31-2005, 11:03 AM   #15
will the viper spec 6 speed fit?
-Denver
Old 05-31-2005, 11:21 AM   #16
its the same as all the other 6 speeds to my knowledge, perhaps a hydrolic clutch link up but im sure that can be altered. The only advantage is its .50 final drive... a normal ford cobra 6 speed sucks for ratios... the final drive is like .62... wtf is that.... I belive the camaro's also share the .50 final drive but not sure on that... either way its a waste of money just upgrade to a 5 speed unless you are a HARD CORE autox'er else you are just slowing yoru car down (as far as the ford gear ratios go, not sure about the others... but that sucker is heavy)
Old 05-31-2005, 02:00 PM   #17
Bane-'s Avatar
ford sell a t56 for the 5.0/5.8 foxbodies
http://www.fordracingparts.com/parts...tKeyField=5955
im sure you could get a diff bellhousing and make it work. my 88 is the same as anything else from 79-04 chasis and **** wise. just different bodies.
but its about 1200 over ur limit brent
Old 05-31-2005, 02:14 PM   #18
Zim
You want to **** me?
Zim's Avatar
whats a t-56 cost these days?
I like toys
Old 05-31-2005, 02:27 PM   #19
3k I believe
Old 06-05-2005, 12:39 PM   #20
bbunt302's Avatar
Like Brandon said, a stock T5 will hold 400 horsepower depending on how it's driven. Don't expect to be powershifting though and pray you don't miss a gear. If it's just going to be a daily driver with the occasional speed shifting, it should be okay though.
The only way you'll be able to get a stouter tranny with that budget will be to buy one used.
Scary stuff.
Old 06-05-2005, 12:53 PM   #21
hydrolic
Damn, and nick says i cant spell
Old 06-05-2005, 01:05 PM   #22
I liek gramer
WhiteStang99's Avatar
a lot of yall can't spell, but I've chilled out about it lately, I'm having to proof all these new articles.
Old 06-05-2005, 01:20 PM   #23
to Nick not being a grammar nazi any more.
2000 manual Tranny a00v6stang Pre-2005 V6 Mustang 5 12-18-2005 04:39 PM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
01:48 AM
