cam and sct chip tune gains? - Mustang Evolution
Old 05-22-2005, 09:21 PM   #1
Send a message via AIM to tedness
if i get just a cam and a tune w/ an SCT chip what kind of gains am i looking at, and what size cam should i get?
tedness is offline   Reply With Quote
Old 05-22-2005, 09:53 PM   #2
If your not going to do the Intakes and don't have dual exhaust ,your not going to see that much increase in HP.
GT-Eater is offline   Reply With Quote
Old 05-22-2005, 10:03 PM   #3
slvr2000stang's Avatar
It will give you some but as stated it's just one piece to a bigger puzzle.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 05-23-2005, 06:24 PM   #4
with just a cam and 92 octane SCT chip you will see about 20 hp increase depending on which cam you get. if you do the cam you might as well get new heads cause you will need new pushrods and new valve springs. the heads will also compliment your cam very well and give you even more hp. like stated earlier, " it's all just part of a bigger puzzle. "
bigpomps is offline   Reply With Quote
Old 05-23-2005, 06:31 PM   #5
Push rods depend on how much you mill the heads ,I still have stock pushrods
on my set up but I also have adjustable rockers
Old 05-23-2005, 06:40 PM   #6
Figure out what you want as a goal for your car and build toward it.
2000 Vert 4R70W
Old 05-30-2005, 12:45 PM   #7
I got 28rwhp with the 207 cam on a stock engine and an untuned chip. But I had a good dual setup with stock headers.
2000 5sp.
216rwhp 235rwtq~damn stock t/b
4.2,Gaston Heads,SSM intakes,207 cam,AMS chip,and the usual
RGR cam,70 t/b,and way better intake awaiting install
1kwik6 is offline   Reply With Quote
Old 05-30-2005, 02:25 PM   #8
Just think what you could get with a better cam and ported heads and intakes, and a dynotune .
Old 05-31-2005, 08:39 PM   #9
97Stallion's Avatar
That's sorta true. The pushrod's length is really going to rely on you cam lobe, but milling the heads will help you use shorter pushrods if you get a reground cam. Reground cam need longer pushrods though if you have your stock rockers or non-adj. rollers. Best over all option though is to get adj. roller rockers like GT-Eater has, that way you don't have to waste money buying certain length pushrods.
Living one day at a time!
Old 05-31-2005, 08:58 PM   #10
jimmy_beaner's Avatar
Region: Iowa
if you're gonna do cam, do port and polish too
Old 06-01-2005, 10:02 AM   #11
RGR
Send a message via AIM to RGR
Some have gotten around 50 RWHP with a cam and tune.
But most get around 30 and the new profiles can better
that with proper spec matching. Head Porting will help some
but like the puzzle analogy goes, your existing pieces may
be the best ones for your total picture. The intake porting
probably makes more sense than head porting for a mild street
3.8 with a cam. I have verified 13RWHP/16RWTQ gains with
street porting on a 99 V6 5 speed. Intake porting only, no
other changes.
The head porting also changes the cam requirements, proper
E/I flow ratios will change the split on the cam. You do not
need extra flow at the expense of velocity, but proper mild
porting of the intake ports enhances velocity and flow = teh win!
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
sct tuner gains edross 1996-2004 Mustang GT 13 09-16-2009 08:53 PM
SCT chip or SCT Programmer? ninty6stang 1996-2004 Mustang GT 7 07-02-2008 11:57 AM
SCT Tune / Dyno #2 Results 2005RedGT 1996-2004 Mustang GT 9 02-21-2005 09:36 AM
Chip tune charkelly9 Pre-2005 V6 Mustang 7 09-04-2004 10:05 PM
02:34 AM
