2001 automatic 410 gear replacement - Mustang Evolution
Old 05-24-2005, 04:15 AM   #1
I am wanting to switch to 410 gears what all will i need? I don't need tloc, but i need to know how to get the speedometer correct and if the transmission will shift properly. I got the gears for $125 and my friend is doing the install (what all will we need) to do the job? also what can I expect for top end speed?
DelawareDave is offline   Reply With Quote
Old 05-24-2005, 05:16 AM   #2
Danger Dude's Avatar
Why dont you need tloc. I think it is such a waste not to take full advantage the tloc provides. Traction to both rear tires not just one. You want to make it go fast but you are going to skimp on a real performance gain?????. Honestly I would not waste any money with gears without tloc.
Old 05-24-2005, 06:07 AM   #3
slvr2000stang's Avatar
I agree with Corey.
And you will need a chip or flasher to correct the speedometer, that is the only way on a 99+ automatic.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 05-25-2005, 06:02 AM   #4
www.gefracing.com has the best price on the 7.5 tlok. Do you have an install kit with shims? If you replace the carrier I would also do new bearings and races, and possibly new bearings and races on the pinion too.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 05-25-2005, 11:45 AM   #5
Unless your friend is a TRAINED professional that knows how to set backlash, pinion depth, set the crush sleeve, check the gear wear pattern, do NOT let him install them... they will more than likly whine and drive you insane if not break and take your whole rear end with it... I am only telling you this cuz such things have happend to me and others I know its a very very bad idea... I dont even recommend using used parts... especially Tlok units.
You need to get a tlok unit its the SAME amount of work to stick one in and if you care anything about perofrmance you will want one also.
a good install usually runs 200-300 pay the extra to get it done by a pro however and get a warranty on the gears for whinning. OEM ford brand is the best to go with when it comes to gears. richmond are known to whine due to their design.
Old 05-25-2005, 11:54 AM   #6
There is also another place that is good for Tlok's and bearing kits www.differentials.com. They are about the same price and are always stock. I have beeen turned off lately with the policys of GEF with their no return on any installed parts.
Old 05-25-2005, 12:20 PM   #7
The guy doing the install knows about backlash and the technical stuff he has done other stangs just not the 01' I guess I will have the tloc it all just cost a little more than I thought. 169.00 for tloc and $300.00 for a predator flash unit anything else????
Old 05-25-2005, 12:29 PM   #8
You will need a install kit for around $60-$80 it includes new bearings. This is a must
Old 05-25-2005, 01:58 PM   #9
My bearings ran me 60 bucks, I just had the shop charge me for them. You will definatly want to replace them for sure. Other than that you seem to be set. If you had a manual you could have got a speedcal unit and solved the speedometer problem but oh well.
Old 07-23-2005, 08:30 AM   #10
ok it took two months but i finally got the tloc from gefracing because they were on national backorder or so I was told.
If I get the work done without the chip or flash tuner do you think this would tear up the transmission due to rough shifting and whatnot???
Old 07-23-2005, 09:11 AM   #11
That is not exactly true. I replaced my T lok a few weeks ago. I contacted GEF and they said the same thing to me and I called www.differentials.com and I had one the next day. They are never out. They carry every make and model differential for just about every car on earth. Plus the guys who take the orders are tech people also so they will never sell you anything not needed. It cost me $20 more than at GEF but there is no wait.
Old 07-23-2005, 09:14 AM   #12
ok they lied
anyway if i go ahead with the install will it hurt transmission until i get a chip or flasher???
Old 07-23-2005, 09:35 AM   #13
ok they lied
That is why I try not to use GEF. No it wont hurt your tranny
Old 07-23-2005, 09:44 AM   #14
GEF has always been very very fast in getting my items to me, I have yet to have one bad experience from them. I always know what I am looking for so I cant say they dont lie and what not...
Old 07-23-2005, 10:06 AM   #15
Well that is good for you but Paul Greenflash00 can vouch for their less than honest service. He ordered a Tlok and 4.10 gears and they said they were in stock. He gets the gears and a letter saying the Tlok was on backorder. They would not cancel the order. When it finally came he came up here to Greenville to have them installed. The gears made a terrible whine. They try several times to readjust the gears ands it was useless. The place specializes in gears and differentials installation and they said the gear set was bad. GEF would not take it back or send new ones saying " they had been installed and voids the warranty" What a load of crap. But they did say they would give him 10% off the next order. What a pile of crap. Paul ordered a used set of gears from Terry @ Midwest and all was good.
Ok for my problems When I bought my 98 cobra rims from them they sent me 2 that were not true They had flat spots. When I called them they asked if I had installed tires on them. I said yes. They proceeded to tell me " They were sorry but the warranty was void since tires were installed and were somhow damaged on the installation equipment. Total Horse ****.
Their warranty means nothing. They dont stand behind what they sell, they try to weasel out of any responsibility to replace anything. Remember GEF is Gene Evans Ford. They are a dealership that added a performance shop to their dealership and as a dealership they can be weasels and try to squirm out of any warranty issue they can.
Old 07-24-2005, 03:16 PM   #16
I ordered the tlok early june and finally got it mid july. had to talk to someone in parts they had the order confirmed and told me they were on back order and if i would like a refund. I told them i just wanted the gears
Old 07-24-2005, 03:28 PM   #17
I am glad for you but they still lied because they were not really on national backorder. I ordered mine in mid june and got it in a day.
2001 DPFE replacement oyarsa Pre-2005 V6 Mustang 5 11-07-2008 09:10 AM
F/S... possible parting out 2001 v-6 automatic jimmy_beaner Mustangs for Sale and Wanted 18 05-02-2006 04:00 PM
Automatic replacement handles ASSEMbler Pre-2005 V6 Mustang 5 11-19-2003 04:21 AM
Automatic Gear Shift Change luckyman Mustang Audio & Video 9 08-20-2003 06:50 PM
410 gear speedo question Freds3.8 Pre-2005 V6 Mustang 23 07-21-2003 02:07 PM
03:17 PM
