another 4.2 question - Mustang Evolution
Old 05-24-2005, 06:03 PM   #1
Send a message via AIM to charkelly9
so this summer im serious about this 4.2 swap but need more info... all i need is a crank pistons rods ? but will the 4.2 forged pistons be the same width(diameter) as the 3.8? Also what would a forged crank heads rods... plus cam intakes rr push rods springs cost.. the total rebuild? If im going into the engine shouldnt ido it all the first time?
charkelly9 is offline   Reply With Quote
Old 05-24-2005, 06:06 PM   #2
constact rpm-mustangs.com for cost's. i believe you only get bigger pistons if you bore out the engine, the stroke is really just the crank shaft.
Old 05-24-2005, 06:43 PM   #3
You need:
4.2l Crankshaft
Pistons
Rods
Cam
Heads (depends on how much you want to pay.. you can go big valve or not)
Adjustable Roller Rockers 1.7
New Springs
Pushrods
Lower Intake
Upper Intake
Crankshaft Bearings
Cam Bearings
Rod Bearings
Rpm can get you every gasket you need for the swap.
You can order the pistons to any engine bore. Which means yes the pistons you get will fit your stock bore.
However if you are going to go to this trouble I would just take the engine out, tear it down, bore the block .030 over and order pistons to match it. This will insure a good clean block and a bit more displacement.
However you can stay with the stock bore.
The 4.2l crank is not forged but can handle a ton of power.
As for cost email sales@rpm-mustangs.com to inquire.
It will be around 2500-3000 dollars for everything you would need, that is what I would guess.
Old 05-24-2005, 06:54 PM   #4
Heres what im thinking.... RPM 4.2 stroker....INCLUDES
clevite 77 pistons
OEM 6.091" connecting rods
clevite77 moly top piston rings
clevite 77 main & rod bearings
New 4.2 crankshaft
rotating assembly balanced
stock balancer & flywheel/flexplate
+$420.00 forged split port dish
= $1500 after core charges excluded
Next i will need Camshaft kit... including
intake manifold-timing gaskets
12push rods
pedestal shims
custom cam
=$350.00
Next roller rockers
1.73:1
+$255.00
Next upper and lower intakes....
=$400.00
Next halfshafted throttle body 65mm
=$150.00
Is this everything excluding a few studs? ... this was taken from RPM site... is there anything else i would need- also this seems like more than i can afford all at once if someone was do to the complete engine rebuild in stages what would you do? Total $=2655.00
sounds nice but i still need to drop tons on suspension and rear.. however now i have a goal and have an idea what too look for in the future..thanks for all help
Old 05-24-2005, 08:02 PM   #5
slvr2000stang's Avatar
Talk to Mik there with all of your questions.
He will guide you in the right direction.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 05-24-2005, 08:39 PM   #6
ive heard this alot lately.. Mik mik mik.. i def. think i need to talk to this guy
Old 05-24-2005, 11:27 PM   #7
werd
Old 05-25-2005, 06:33 AM   #8
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
clevite 77 pistons
New 4.2 crankshaft
12push rods
pedestal shims
custom cam
=$350.00
Next roller rockers
1.73:1
+$255.00
=$400.00
=$150.00
get forged rods, not OEM rods. in an engine pushing a lot of power, the first thing to go is the weakest link. in this case, OEM rods
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 05-25-2005, 06:48 AM   #9
Danger Dude's Avatar
You need help with life you call on.......................................GOD
You need help with your health you call on a.........................DOCTOR
You need help with your car you can call on..........................US
When you need to know all about a 4.2 conversion you call on..MIK or Rob 97Stallion!!!!
Old 05-25-2005, 10:22 AM   #10
haha soo true dangerdude... im emailed mik and should be getting feedback soon.. thanks for your help
Old 05-26-2005, 10:57 AM   #11
97Stallion's Avatar
What about me? I think you should rephrase that. As far as I know I'm the only one selling 4.2 conversion kits that actually has done it. So when you need any info on a 4.2 Kit, contact me!!!
Living one day at a time!
Old 05-26-2005, 11:24 AM   #12
I am sorry to leave you out of the mix Rob ARRGGGHHHHHHHHHHHHHH!!!
By the way I have edited it GO LOOK !!!
Old 05-26-2005, 07:40 PM   #13
rob with all do respect to mik you have acutally done the conversion and ive seen it plus i can get ahold of you a lot easier... could you pm me with your 4.2 conversion kit..plus an idea what an entire rebuild would run?> thanks for your help.. this summer i might be ordering some toys.
Old 05-26-2005, 09:03 PM   #14
97Stallion's Avatar
Sure thing!! I'm currently inNebraska for my wedding on Sat. I'll PM you once I get home ok? I think I have your e-mail also.
Old 05-26-2005, 09:28 PM   #15
19ClearCobra96's Avatar
Region: Nebraska
Send a message via AIM to 19ClearCobra96 Send a message via MSN to 19ClearCobra96
you wouldnt be in imperial nebraska would you be?
19ClearCobra96 is offline   Reply With Quote
Old 05-27-2005, 12:53 AM   #16
97Stallion's Avatar
Yes, I'm just south of Omaha, in Bellevue, near Offutt AFB
Old 05-27-2005, 08:29 AM   #17
Im just waiting on the site to change names to Mik is god and all other suck
96 GT 4.6 L
Ported 2004 Upper Plenum
B&M Shifter
Bassini O/R X Pipe
FRPP Adjustable Clutch Cable
UPR Extreme Triple Hook Quadrant
UPR Extreme Firewall Adjuster
Ford 11"Clutch Conversion
C&L MAF
WMS CAI
Aluminum Drive Shaft
95 V6 Vert: 4.2L swap, Trac Lock, Light Cam, Mac Shrorty Headers, More to come.
AlmostN8 is offline   Reply With Quote
Old 05-27-2005, 08:37 AM   #18
Well he is a site sponsor
Old 05-27-2005, 08:44 AM   #19
Also a pretty good way to guarantee no one else is as well.
96 GT 4.6 L
B&M Shifter
Bassini O/R X Pipe
C&L MAF
WMS CAI
Old 05-27-2005, 08:57 AM   #20
Mik runs a very good bussiness, and some of his past customers trust only him. But we are not saying all others suck, you guys must be doing something right to get that green stang in the 10's
Old 05-27-2005, 09:41 AM   #21
I will be quite honest here. Nobody is bashing anyone here. I have said in my post both Mik@RPM and SSM are great companies. But as a site we do promote good standing sponsors and RPM is one of the best V6 companies around. For that we need not apologize. SSM can come in at anytime and advertise. Hell at next UMC Track day they can also help ME sponsor the V6 shootout. VMP and Fordchip did last year.
There is no hate for any quality companies and there is business to go around!!!
We are all friends here and lets be decent!!!
Old 05-27-2005, 11:05 AM   #22
Region: Nebraska
Just wondering because a buddy of mine is going to a wedding n imperial this weekend too.
Old 05-27-2005, 08:28 PM   #23
http://www.mustangevolution.com/advertise
Old 05-29-2005, 04:11 PM   #24
97Stallion's Avatar
When is the UMC meet gonna be this year? I think I'll sponser it too. Not sure what I can offer, maybe like a gift certificate or something for my site.
Old 05-29-2005, 05:09 PM   #25
dont you mean
http://www.mustangevolution.com/advertising/
Idiot!
Old 05-29-2005, 05:11 PM   #26
Originally Posted by 232stang
haha that too
thanks for the help one more question JAYS MUSTANG Pre-2005 V6 Mustang 3 09-16-2006 10:07 AM
Sub Question graystangguy06 Mustang Audio & Video 9 06-26-2005 12:56 PM
another 3.8-4.2 question. Horse Pre-2005 V6 Mustang 9 07-16-2004 09:37 PM
Question 98VroomVroom Mustang Audio & Video 1 03-28-2004 01:29 PM
Question 98VroomVroom Mustang Wheels & Tires 1 03-27-2004 10:20 AM
07:04 PM
