Any idea what these codes pertain to? - Mustang Evolution
Old 05-25-2005, 03:58 PM   #1
Zim
You want to **** me?
Zim's Avatar
22 - MAP/BP sensor out of self test range 1.4 to 1.6 volts.
29 - Insufficient input from vehicle speed sensor.
85 - Canister purge solenoid circuit failure
67- Neutral safety circuit failure.
31 - PFE or EVP circuit below minimum voltage of 0.24 volts.
PFE or EVP circuit has intermittently failed below minimum voltage of 0.24 volts.
I dunno what the neutral safety circuit is, or that PFE/EVP or MAP/BP... can someone help me out?
I like toys
Old 05-25-2005, 05:01 PM   #2
Tbird232ci's Avatar
MAP/BAP should be on your firewall, it measure barometric pressure, and aids the MAF in air measurement
the nuetral safety circuit is probably the switch that is on your clutch pedal, up top, probably is stuck in the one position, making the car think the clutch is in at all times
im not sure about the EVP, but the canister purge is the system that sends the fumes from the gas tank back into the intake track
Old 05-25-2005, 05:06 PM   #3
the Vehicle Speed Sensor is your VSS sensor its on the side of the tranny where the speedo gear goes. It plugs into the hole along with the speedo gear.
Old 05-25-2005, 05:20 PM   #4
slvr2000stang's Avatar
If you did the test with out the clutch depressed you get the 67- Neutral safety circuit failure
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 05-25-2005, 06:28 PM   #5
Please tell me these aren't showing up on your car.
Old 05-25-2005, 07:05 PM   #6
Zim
Zim's Avatar
theyre showing up on my car
I like toys
Old 05-25-2005, 07:09 PM   #7
Zim
Zim's Avatar
any idea why it would throw any of these codes?
I like toys
Old 05-25-2005, 07:16 PM   #8
I am willing to bet it is something to do with your 4.10s
Possibly someone put a speedo gear in and fudged up the install.
I was wondering why your car was so cheap.. hope it isnt anything big.
Old 05-25-2005, 07:30 PM   #9
Zim
Zim's Avatar
The car runs fine besides it getting really hot at this point. The RPM's also flew up to and stayed at 1800 during idle... I dunno wtf that was about. Im just working on the cooling system right now.
I like toys
Old 05-25-2005, 10:23 PM   #10
Tbird232ci's Avatar
remember, he has an 89-93 computer in there, they use 2 digit codes
Old 05-26-2005, 10:15 AM   #11
my friend got MUCH BETTER radiator for pretty darn cheap, not sure but something about two core. His is now really nice and cool and before he ran hot.
Old 05-26-2005, 11:11 AM   #12
Zim
Zim's Avatar
Yeah if this T-stat doesnt fix anything Ill probably get a new radiator. The deal is, it was sort of a gradual incline in temperature over the past couple weeks, so that makes me think its the radiator because something might be getting clogged up or something to that effect.
I like toys
Old 05-26-2005, 11:50 AM   #13
whats it running at? are you running low on coolant?
Old 05-26-2005, 03:47 PM   #14
Zim
Zim's Avatar
No ive got plenty of coolant... it was running at 240-245* before, so I got it home and turned that sucker off before the coolant got above 265 to start boiling. Im taking it in to have it fixed though, Im tired of trial and error.
I like toys
DTC Codes? oldtexasdog 2005-2010 Mustang GT 2 07-07-2010 08:43 AM
2 Codes Need Help tigerfan2771 Pre-2005 V6 Mustang 12 04-05-2010 09:42 PM
Codes: 94 3.8L winterwolf Pre-2005 V6 Mustang 1 01-17-2010 09:23 PM
How to fix this codes? 6opka Pre-2005 V6 Mustang 11 03-24-2009 09:46 PM
codes plungerlift01 1996-2004 Mustang GT 2 09-09-2008 10:03 PM
03:48 PM
