Newbie with a question. Go figure... :) - Mustang Evolution
Old 05-27-2005, 07:51 AM   #1
streck-fu's Avatar
My 2001 v6 auto has developed an idle issue that i did not see described in the archives (I tried finding the answer through a search first).
When the car is first started while cold, the idle runs up to about 2k before settling to ~1.5k rpms. Once I put it into drive, it drops to about 800rpms. It drives fine and once warm the idle (in park) hovers at about 1100 rpms which is still a little high.
My first thoughts are the idle controller (where is it?), a vacuum leak (less likely), or TPS (even less likely).
What do you guys think?
TIA,
Daniel :patriot:
streck-fu is offline   Reply With Quote
Old 05-27-2005, 09:59 AM   #2
Danger Dude's Avatar
A TPS would more often act up all the time. With out knowing more it could be a vacuum leak but my bet is the IAC Idle air control. The problem going away when you put it is frive is a good indication of a IAC problem. The 99+ drivers side valve cover has a problem with sucking up more oil vapor into the air intake and gets thing pretty grimy inside. Youcan take the IAC off and clean it with carb cleaner and reinstall it.
Old 05-27-2005, 11:23 AM   #3
streck-fu's Avatar
It doesn't really go away when put into drive. It seems that the increased load causes the idle to drop because it will return to ~2krpms (when cold) if put back into park.
I will look at the IAC when I get home. Where exactly is it located?
Thank you for the response.
2001 V6 (daily driver)
1988 Porsche 951 (lightly modified)
1986 Honda VFR 750 Interceptor (in pieces scattered to the 4 corners of the garage)
Giving money and power to government is like giving whiskey and car keys to teenage boys.
-P. J. O’Rourke
Old 05-27-2005, 01:23 PM   #4
my 01 is also odd when it comes to idle, I do have a manual so mine also acts up. Some things to try:
1) Usually your idle bypass valve wont cause this, it will just NOT let the car idle and it will die when in neutral or what not... but its a cheap part and easy to swap. If you look at your upper intake you will see this item on the passenger side next to the firewall, bolted to the intake, its cylinder shaped and the cylinder is nearly mounted side ways.
2) Clean your MAF wires especially if you have an aftermarket air filter... and especially a week after you have re-oiled your aftermarket air filter, then again after a month. Use on contact NO RESIDUE electronic cleaner, get it at autozone or radioshack.
3) Try resetting the computer by taking the negative battery terminal off and then tapping the brake a few times let it sit 30 min to be sure (doesnt need to if you are in a hurry a couple does fine) then crank it let it idle for 3-5 min then drive it normal and hard then normal and let it sit for 3-5 min at idle and turn it off. See if this helps.
4) The idle decay rate is controled by the computer its what causes the rpms to slowly drop vs drop like a rock, mine every now and then will get stuck.... aka the rpms will stay way high at a given rpm and wont come down, in this case the mine fixed its self, but yours may not. To fix you can get a chip set to recalibrate the idle decay rate and what not but its probably the most expensive out of any of these to fix.
start with the maf wire cleaner then the idle bypass valve first.
Old 05-27-2005, 06:43 PM   #5
Mine idles a little higher at park...but goes down. I dunno what it did before the chip, but I'm sure it was all changed.
Old 05-31-2005, 07:40 AM   #6
streck-fu's Avatar
Thanks for the info. I'll check those out! :thumbs2:
-P. J. O’Rourke
Old 06-01-2005, 10:20 AM   #7
RGR
Send a message via AIM to RGR
Good to see more INDIANA peeps on here!
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Cant Figure it Out saleenman 1996-2004 Mustang GT 3 08-11-2009 05:20 PM
quick newbie question selfinfliction Pre-2005 V6 Mustang 6 05-25-2008 08:06 PM
Help Me Figure Out Where This Goes Brent Pre-2005 V6 Mustang 6 09-19-2007 08:32 PM
Newbie Question, Transmission? getgo 1979-1995 Mustang GT 8 07-22-2004 01:44 PM
Really Dumb Question *Newbie Warning* 98Blue232 Pre-2005 V6 Mustang 33 08-02-2003 10:33 AM
02:05 PM
