Power Steering? - Mustang Evolution
Old 08-26-2009, 08:15 PM   #1
NeedSomeMods's Avatar
Unhappy Power Steering?
I have an issue with power steering on my 2000 V6.
It makes that oh-so-annoying high pitched sound like you're low on power steering fluid, but I know I'm not low because I am always reminded to check it to make sure I'm not.
It hardly takes any effort at all to turn so I don't think it's going out.
This has been going on for a long time but it has gone far past the point of simply ignoring it.
I had the tires rotated not long ago, that changed nothing.
My mechanic friend suggested I completely drain the fluid, flush it, and then refill it with clean, new fluid. I don't think this has ever been done to me car.
Any suggestions?
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 08-26-2009, 08:22 PM   #2
Re: Power Steering?
try this, it looks cheap
How to fix squeaky power steering
ThaWill is offline   Reply With Quote
Old 08-27-2009, 01:43 PM   #3
Re: Power Steering?
Okay I jus tried that, thanks, but it didn't work.
Anyone else have any suggestions?
2000 V6 - RIP
The '94 -
Old 08-27-2009, 02:02 PM   #4
SaleenFiend's Avatar
Re: Power Steering?
Get a new powersteering pump more than likely is failing on you.
Old 08-30-2009, 01:23 AM   #5
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: Power Steering?
That Power steering flush really does help. It all depends on how bad off the pump is to begin with but I've had noisy ford pumps quiet down very noticeably after doing a flush.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
power steering whine help? mikehailey02gt 1996-2004 Mustang GT 6 06-24-2009 09:06 PM
Power steering rack Haohmaru 1979-1995 Mustang GT 2 05-12-2008 12:36 AM
power steering help '70 mach1 flashback Classic Mustangs 2 06-08-2006 11:51 AM
Power Steering? Ibanezplayer272 Pre-2005 V6 Mustang 5 11-28-2004 12:11 AM
power steering issues WhiteStang99 Pre-2005 V6 Mustang 16 06-22-2004 06:08 AM
07:36 PM
