4.2 not running right... I guess - Mustang Evolution
Old 08-29-2009, 11:39 AM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
So I installed the 4.2 into my mustang, made it look all pretty, but they my tuning chip that I mail ordered wouldn't work. Car would fire up, idle down and then die right away. So I rented a trailer and took it to a dyno shop. They tuned it but said that they couldn't figure out an idle problem. So I got it towed back to my shop so that I could work on it, since they said they were really busy and didn't have time to look at it. They said that it would run fine for about a half hour, then run poorly and die. Then it woudln't restart for a few hours. It's not overheating, so I figured it was something electrical. Well, the car is currently sitting in the shop running. Has for 45 min. It ran well over an hour last night after work too. They took the tune flash back out of the PCM before I got it back, "so it would be easier to trouble shoot." Not a lot of help since it runs without dieing now. I scanned it and got a p0602 code. Which is a code set when the PCM is in need of a reflash, or replacement. This is really getting aggrivating. I'm down about $200 for trailer rental and tow service and they didn't do a god damn thing.
Does anyone have any advice?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 08-29-2009, 11:44 AM   #2
Re: 4.2 not running right... I guess
you sure the pcm/wiring nharness/etc all match up?
Old 08-30-2009, 01:12 AM   #3
Region: Iowa
It's the same PCM and harness that have always been in the car. I've removed and reseated the PCM connector. Seems good to me. I've also tried getting it to run with a mail order SCT chip, but the car won't run AT ALL with it in. Starts after a long crank and dies right away. You can't even feather the throttle and keep it going.
Old 08-31-2009, 10:32 PM   #4
Region: Iowa
Wow. 30lb injectors on the stock tune, and the computer thinks bank 2 is lean. 20% positive fuel trim. O2 sensors check out. So does the wiring between O2 sensor and PCM. Time to start pulling the upper intake and checking the injector harness I suppose. *sigh* I was supposed to be nearly done with break in by now. Damn it.
Old 09-01-2009, 04:22 AM   #5
jimmy_beaner's Avatar
Region: Iowa
in a related note... wanna help me install some trickflow heads in the next year
The luck you're having with this car really sucks. I hope you can get it turned around and that the motor will be a solid runner for you.
Old 09-01-2009, 07:33 AM   #6
SaleenFiend's Avatar
Long shot, but are you sure your fuel pumps aren't failing?
Old 09-02-2009, 10:12 PM   #7
Region: Iowa
Well, I have only one fuel pump, but that one's working fine. 300LPH should be sufficient once I get the thing tuned.
I think I figured out the lean problem. The bank that's lean is the bank opposite the fuel feed. With the pass. side injectors cranking out WAY too much fuel, I think the rail pressure might be low on the drivers side. Either way, I can't get it to die the way the Dyno place said it did when they tuned it, so I drove it back over there. The think won't come down off higher RPM to Idle worth crap and the plugs are getting fuel fouled. Hopefully they'll believe me that the car runs "ok" without their tune and they'll figure out what went wrong. I'll keep everybody posted.
Old 09-02-2009, 10:13 PM   #8
Region: Iowa
P.S. even with a ****ty tune and not idling for crap the motor has quite a bit of torque, so that made me happy at least. This was the first chance I had to drive the thing at all since I tore it apart around the middle of June.
what should i be running? tigercrazy718 General Mustang Discussion 0 05-19-2010 02:31 PM
running bad help please scott3.8stang 1996-2004 Mustang GT 4 05-09-2009 11:14 PM
We got them running now Brent The Bar 7 02-14-2007 06:46 AM
Running the V-6 05STANG Pre-2005 V6 Mustang 5 02-13-2006 07:36 AM
Need a Running Pony lowflyn Mustang Audio & Video 11 08-23-2004 11:33 AM
10:56 PM
