is it just me? - Mustang Evolution
Old 08-31-2009, 06:16 AM   #1
Send a message via Yahoo to Senorjizzy
is it just me?
or am i paranoid... but it seems ever since i have installed my cai that alot of heating/temperature problems have occured. i was just wondering if maybe that the cai could have a ny effect on that..
maroon 1998 mustang V6 auto. AM cai. Raxiom black headlights )
Senorjizzy is offline   Reply With Quote
Old 08-31-2009, 07:19 AM   #2
Re: is it just me?
if you installed it correctly then it should be fine, you can check for leaks where air might be getting around or through openings but not sure that would have any effect on the car over heating
Old 08-31-2009, 08:18 PM   #3
Re: is it just me?
well ik there mite be a slight leak, because there was a problem with one of the bolts that went to the MAF, but other thn that theres nothing.
Old 09-01-2009, 07:45 AM   #4
SaleenFiend's Avatar
Re: is it just me?
I highly doubt your CAI is causing a overheating issue, but I would check that you didn't damage, unplug, disconnect, or change anything while you were installing the CAI.
To help eliminate the overheating I would start by burping the system. Try changing your thermostat.
10:44 PM
