Need Help! 94 Mustang V6 - Mustang Evolution
Old 08-31-2009, 10:24 AM   #1
Exclamation Need Help! 94 Mustang V6
I was trying to replace the right rear axle shaft when the lock bolt that holds the differential pinnion shaft broke in half. I was thinking of taking the axle to a shop and having the bolt extracted. Would this be a good time to upgrade gears and if so to what? I have a 94 Mustang Coupe, manual transmission.
ljefe94 is offline   Reply With Quote
Old 09-01-2009, 01:24 PM   #2
SaleenFiend's Avatar
Re: Need Help! 94 Mustang V6
You broke one of the bolts that attatch the ring to the differential? I'm not understanding what bolt you are speaking of?
Old 09-02-2009, 09:25 AM   #3
You can see the bolt once you take the differentila cover off. It's the diffrential lock bolt, thanks
06:09 AM
