gears - Mustang Evolution
Old 08-31-2009, 02:18 PM   #1
blackonblack's Avatar
gears
i would like to put new 4.10 gears on. do i HAVE to fix anything else if i got gears put on? do i have to have t-lok? if i dont want, would some problems be
blackonblack is offline   Reply With Quote
Old 08-31-2009, 03:21 PM   #2
Re: gears
You don't have to have a t-lok, but most do both while they're at it.
19Delta is offline   Reply With Quote
Old 08-31-2009, 03:50 PM   #3
Re: gears
its the same amount of work to put in a tlok with the gears or just the gears so the install price should be almost identical. Its also only 200 more for a tlok and they are a must for performance.
Old 08-31-2009, 03:50 PM   #4
Re: gears
You don't have to install a tlok with gears, but I would. They can be installed at the same time as the gears, and you only need friction modifier along with the tlok. It will help with acceleration and launches, not to mention two wheel burnouts.
I'm assuming you are installing the gears on a v6...if it is a v8, you could keep your old tlok and rebuild it.
Along with the gears themselves, you'll want gear oil (Royal Purple is a good brand), and a bearing kit if your car has higher than 50k miles.
Old 09-01-2009, 11:59 AM   #5
The Darkside's Avatar
Re: gears
dont forget you will need somone to retune the car, or reprogram the computer so it knows you have 4:10 gears, otherwise your speedo will be off and if you have an auto your shifts will be off as well.
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 09-01-2009, 01:03 PM   #6
SaleenFiend's Avatar
Re: gears
Can we get a sticky and FULL WRITE UP FOR GEARS? With directions to go and sources for parts for every one? I don't have the time right now.. but when I do I am going to make a huge sticky...we get 5-6 gear threads a week now.
Old 09-01-2009, 03:21 PM   #7
Re: gears
^^^+1
Old 09-03-2009, 11:05 AM   #8
Re: gears
Gears are a popular question lol
i bleed Race fuel!
Old 09-03-2009, 11:22 AM   #9
OsirisGuy's Avatar
Re: gears
I'm trying to strart one up now.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 09-03-2009, 12:35 PM   #10
2007STANG's Avatar
Region: West Virgina
Re: gears
trust me go for the gears and tlock just had mine done what a good move
Billet fuel door, Daiblo 91 Tune, Xenon ram air hood scoop, MAC performance direct fit headers, 3" 304 SS Dual exhaust, hood pin appearance kit, Red l.E.D. underbody lights, Boy Racer rear wing, Helix power tower plus Throttle body spacer, ventvisor deflector, Aeroform chin spoiler, SVT 18" 9.5 45/255 frount SVT 18" 9.5 40/285 rear trire , GTO rear blackout kit, OEM rear splash guards, Steeda CAI, 8.8 rear axle with 3.73.1 LSD, killer Glass Hose, Smoked Window Louvers by GT Styling 35% Tenting on rear and side windows.
2007STANG is offline   Reply With Quote
Old 09-03-2009, 12:44 PM   #11
Re: gears
once you get a how to get with me and we will get it posted up in the article section, go in full detail on the math to calculate higher rpms, etc etc
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
3.73 gears tim11 Pre-2005 V6 Mustang 5 10-25-2005 08:21 AM
4.10 gears powerhungry966 Pre-2005 V6 Mustang 7 10-23-2005 06:53 PM
gears 8.8 or 7.5 strike1980 Pre-2005 V6 Mustang 5 07-31-2005 11:05 PM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
04:40 AM
