Coolant question - Mustang Evolution
Old 06-07-2005, 12:25 PM   #1
Coolant question
I don't have an owner's manual yet because the dummy at the dealership takes his time. I've got a 2004 3.8 and I noticed that there's a sticker on the plastic coolant recovery container that has orange coolant and a red circle with a slash through it indicating "NO". The problem is mine has orange coolant in it, and I don't know if it's a problem.
Someone said the orange was usually the environmentally friendly stuff, but didn't know if it was regular coolant colored orange, or if it was something called Dex-Cool or something like that.
I'm confused as to what I should use and what I should do if there is a problem.
bryanscle is offline   Reply With Quote
Old 06-07-2005, 12:51 PM   #2
Drain the coolant, flush the system VERY well, and replace with green coolant. The orange stuff eats up your heads, intakes and radiator. Do it now.
96 GT 4.6 L
Ported 2004 Upper Plenum
B&M Shifter
Bassini O/R X Pipe
FRPP Adjustable Clutch Cable
UPR Extreme Triple Hook Quadrant
UPR Extreme Firewall Adjuster
Ford 11"Clutch Conversion
C&L MAF
WMS CAI
Aluminum Drive Shaft
95 V6 Vert: 4.2L swap, Trac Lock, Light Cam, Mac Shrorty Headers, More to come.
AlmostN8 is offline   Reply With Quote
Old 06-07-2005, 01:49 PM   #3
Actually you have a 3.9
97 V6 stang
BBK CAI
50 series muffler, coming straight out of the muffler and 2 of 4 cats removed
reverse indiglo guages
nice system
clear corners
euro taillights
50mm TB halfshafted P&P from RPM
auto6banger is offline   Reply With Quote
Old 06-07-2005, 02:19 PM   #4
Ponycarman's Avatar
The propolyene glycol (orange stuff) is not environmentally friendly. It is just not quite as toxic as the ethylene glycol (green stuff). That all being said glycol of any type is clear so the coloring isn't a good indicatior of what type it is. It's all dyed anyway.
As for the Dex-cool eating stuff. :bs:
My GM had over 130K wil no issues. Like anything if you fail to maintain the cooling system things will fail. The Dex-Cool got a bad rap because it was a symptom of a poor intake gasket design. On some of the GM 60 degree V6's the intake manifold gasket would fail and allow coolant to leak into the oil. ANY type of glycol in the oil will eat the bearings. Which is exactly what happened and ignorant people blamed it on the coolant, not the intake gasket.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 06-07-2005, 02:49 PM   #5
i'm not sure if the orange coolant is bad as long as it was flushed properly. I've heard the reason they put those warnings there is because if you mix the green and orange it gels and that would be bad
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline   Reply With Quote
Old 06-07-2005, 03:21 PM   #6
just use what it has, it will be fine. The new ones have the orange stuff in em.
Old 06-07-2005, 04:52 PM   #7
NorwegianMustang's Avatar
Send a message via AIM to NorwegianMustang Send a message via MSN to NorwegianMustang Send a message via Yahoo to NorwegianMustang
Hm, I got the blue one
Mods: Magnapacks, BBK X-pipe with cats, BBK CAI, hood struts, KYB Shocks/Struts, Eibach Pro springs, SS Inserts, CDC Light bar, Chrome 17" Bullits with Nitto 555 and N2O with dual purge
NorwegianMustang is offline   Reply With Quote
Old 06-07-2005, 05:44 PM   #8
Not all 2004 are 3.9
Old 06-08-2005, 07:51 AM   #9
Steve
Which explains why certain manufacturers expressly say NOT to use it... ok.
96 GT 4.6 L
B&M Shifter
Bassini O/R X Pipe
C&L MAF
WMS CAI
Old 06-08-2005, 08:16 AM   #10
Danger Dude's Avatar
I will have to agree with you on this one. Whether it is crappy gaskets or the coolant does not matter I would suggest following Manufactures warning simply for no other reason than to pevent damage to your engine and the dealer not fixing it because it has improper fluid in it.
Just use the green stuff and be done with it.
Old 06-08-2005, 10:57 PM   #11
dang thought they all were, my bad.
97 V6 stang
BBK CAI
nice system
clear corners
euro taillights
Old 06-09-2005, 05:58 AM   #12
Okay, well I went by the Ford dealership and they said that all 2004's, Crown Vics, Stangs, etc. went over to the yellow/gold coolant and that I probably had the gold, but it looked orange so I'm flushing it anyways and putting in the yellow/gold just to be sure
Yes I have a 3.9, just thought I'd use 3.8
Thanks for the replies though
Old 06-09-2005, 09:02 AM   #13
Ponycarman's Avatar
Certain manufacturers expressly state to use their parts to maintain your vehicle.
What does that mean? Nothing more than they want your money. You don't know why they state not to use it, you assume. It may be an incompatibility issue between the factory installed coolant and the dex-cool stuff for all you know, or don't. Fact is the Dex-cool in and of itself is not a problem as long as you follow the maintenance schedule period.
1996 Mustang
1965 Barracuda
Coolant System nay's mustang 1979-1995 Mustang GT 8 12-23-2009 11:12 PM
Coolant level Foxone Pre-2005 V6 Mustang 3 10-13-2009 07:41 AM
Changing coolant soon Mustangfan2003 1996-2004 Mustang GT 9 10-14-2008 08:15 AM
Coolant Change 99v6TxStang Pre-2005 V6 Mustang 6 11-10-2004 06:10 PM
coolant leak josh97gt Pre-2005 V6 Mustang 7 09-01-2004 10:38 AM
12:58 AM
