Trunk light fuse??????? - Mustang Evolution
Old 06-08-2005, 10:53 AM   #1
Send a message via AIM to Murph00
I just finished my sub box, it looks awesome. I decided to put a lil neon tube in the box (box has windows), I wanted the neon to come on when the trunk lid opens so I went to wire it to the trunk lid light, cut the ground and when i put my wires together the light never came back on. does anyone know where or if their is a fuse to this???????????
Murph00 is offline   Reply With Quote
Old 06-08-2005, 04:56 PM   #2
I'm sure there's a fuse to it somewhere...check your owner's manual, I'm too lazy to walk outside and get mine right now, just got in from a long day at work.
Old 06-08-2005, 09:01 PM   #3
The manual would be the 1st thing to check but I lack one, never had 1 when I bought the car/ didnt want to goto ford to buy one, yet
Old 06-08-2005, 09:07 PM   #4
One sec, I'll go grab mine.
Old 06-08-2005, 09:34 PM   #5
Ok, here ya go.
I can't figure out what fuse it might be, but here ya go.
1. cigar lighter
2. engine controls
3. not used
4. rh low bean headlamp
5. instrument cluster, traction control switch
6. starter motor relay
7. gem, interior lamps
8. engine controls
9. mach 460 subwoofers
10. lh low beam headlamp
11. back-up lamps
12. not used
13. electronic flasher
14. not used
15. power lumbar
16. not used
17. speed control servo, shift lock actuator
18. electronic flahser
19. power mirror switch, gem, anti-theft relay, power door locks, door ajar switches
20. convertible top switch
21. instrument cluster and engine control memory
22. not used
23. a/c clutch, defogger switch
24. climate control blower motor
25. luggage compartment lid release
26. wiper/washer motor, wiper relays
27. radio
28. gem, overdrive control switch
29. abs module
30. drl module
31. data link connector
32. radio, gem
33. stop lamp switch, speed control deactivation switch
34. instrument ccuster, ccrm, data link connector, secruilock transceiver module
35. shift lock actuator, pcm, speed control servo, abs module
36. airbag control module
37. adjustable illumination
38. high beams
39. gem
40. not used
41. brake lamp
42. not used
43. power windows
44. not used
Your guess is as good as mine as far as what it is man...
Old 06-08-2005, 09:49 PM   #6
your awesome man thx
Old 06-09-2005, 04:04 PM   #7
hey lowflyn it was fuse #7 thanks again for all your help
Old 06-09-2005, 06:07 PM   #8
np man, I help when I can.
Old 06-09-2005, 06:07 PM   #9
I liek gramer
WhiteStang99's Avatar
wonder what this does?
Old 06-09-2005, 06:17 PM   #10
I kinda wondered about a few of those..what they actually do, or what would happen if they blew.
Like if:
went out....would your cruise control never cut off...
Old 06-12-2005, 12:35 PM   #11
make sure you have the correct wire, check it with a tester.
Dome light fuse Renegade 800 Pre-2005 V6 Mustang 7 09-06-2016 07:45 PM
fuse box? braumab 2005-2010 Mustang GT 5 12-08-2008 03:29 PM
wiring to a fuse Mustangbobby Classic Mustangs 2 08-18-2008 12:48 PM
FUSE SET UP Debras96stang Pre-2005 V6 Mustang 27 06-04-2006 11:17 AM
Fuse problems. Brent Pre-2005 V6 Mustang 6 08-22-2003 01:24 PM
07:26 PM
