Gears - Mustang Evolution
Old 06-09-2005, 03:01 PM   #1
stang-rookie's Avatar
Gears
Okay guys, I am alittle confused...what is the difference between a 8.8 rear end and a 7.5? I have a '01 auto and I was looking for gears and a T-lok, also what gears do I have now(stock) and what is the difference between those and 4.10? Sorry if this is basic stuff, but remember I'm still learning .
Thanks
stang-rookie is offline   Reply With Quote
Old 06-09-2005, 03:15 PM   #2
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
well if your looking to race it you want 3.73 for stick 4.10 for automatic as for the differance between the rear ends 7.5 and 8.8 is the size of ring and pinion axel the 8.8 can handle a hell of a lot more hp and torque.. i believe the 7.5 rear is good for 300hp
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 06-09-2005, 03:22 PM   #3
So I probably have a 7.5 right?
Old 06-09-2005, 03:23 PM   #4
Dark02Pony's Avatar
yeah the 3.8 has a 7.5 the GT has 8.8
Old 06-09-2005, 03:35 PM   #5
97Stallion's Avatar
right, also the 300hp is just a myth. This is something someone came up with a long time ago and some idiot took it as gospel and passed it around. The 7.5 can handle lots of hp and tq, but the 8.8 is definately the better of the two. You have to maintain your rear-end like you maintain the rest of the car. If you don't change the fluid annually to remove water, you're basically gonna have a rear-end that has water for lube. NOT good. Hopefully this will edumacate you some.
Living one day at a time!
Old 06-09-2005, 03:50 PM   #6
So what is the best way to go, 4.10 gears and T-lok with my 7.5, or find a 8.8 that already has 4.10 gears and a T-lok?
Old 06-09-2005, 04:51 PM   #7
97Stallion's Avatar
well either actually, I would go with the 8.8 with the gears already in it first because you'll have a stronger rear for the same price basically. New gears and a t-lok will run you bout 400 or so. Install will run you about another 200-300, so about $700+/- some for the whole thing. An used 8.8 will run you about the same amount.
Old 06-09-2005, 06:57 PM   #8
It mostly depends on what you want out of your car. If its gonna be a track horse then I would go w/ an 8.8 and 4.10's. If your looking for a few bolt ons for the street stick w/ the stock 7.5 and throw in the 4.10's.
2002 Mustang GT, 5-speed, torch red. K&N, 3.73 gears, flowmaster cat back, and lots of love.
1991 5.0 lx conv. auto, black. Full saleen body kit, cold air intake, msd ignition, flowmasters, off road h-pipe, underdrive pulleys, trickflow intake, trickflow stage 1 cam, 190 lph fuel pump, 30 lbs injectors, 73mm mass air.
http://www.mustangevolution.com/gall...0632_thumb.jpg
saleen0027 is offline   Reply With Quote
Old 06-09-2005, 07:00 PM   #9
If you can find a 8.8 with the gears you want for around the same price as gears and install on the 7.5, get the 8.8, otherwise just go gears and t-lok.
Old 06-09-2005, 10:41 PM   #10
Kiljosh's Avatar
I would get an 8.8 with gears already in it, because the install is 1000x easier unless you **** with ABS. A stock 7.5 is good for awhile, as long as you maintain them(like 97stallion said) and you don't run slicks and hook up at the truck. You'll destroy the rear.
Old 06-10-2005, 07:00 AM   #11
So can I go to a junk yard and find a rear off a GT? If so, does it have to be from an '01 with an automatic tranny or will other years fit?
Old 06-10-2005, 07:54 AM   #12
Kiljosh's Avatar
Yea, you can goto the junkyard and TRY to find a GT. I don't know about around you, but up by me all the people seem to get to the cars and absolutely GUT them before I can get up to the junkyard.
The rear has to be from a 99+ GT definitley. You might have to get the driveshaft if you take it out of a 5-speed. It's prob a better idea to look around on ebay or the internet and see if anyone has a rebuilt one fully assembled for sale. And make sure to read the tag on the pumpkin. It has info in it about the gear ratio and if it's a locking diff or not.
One thing I don't know about the swap is if you switch from a 7.5 to an 8.8, do you have to go with quad-shocks in back? Maybe someone can answer this...
Old 06-10-2005, 04:25 PM   #13
it will vbe very hard to get an 8.8 at a junk yard
Old 07-28-2005, 10:26 PM   #14
im getting gears for my 7.5, do i need the yukon master install kit or will a shop have everything needed
Tony
2002 Silver V6 Mustang
my garage http://www.mustangevolution.com/gara...do=view&id=273
TBone is offline   Reply With Quote
Old 07-28-2005, 10:33 PM   #15
the shop should have everything.
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
3.73 gears tim11 Pre-2005 V6 Mustang 5 10-25-2005 08:21 AM
4.10 gears powerhungry966 Pre-2005 V6 Mustang 7 10-23-2005 06:53 PM
gears 8.8 or 7.5 strike1980 Pre-2005 V6 Mustang 5 07-31-2005 11:05 PM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
06:19 PM
