Thermostat - Mustang Evolution
Old 06-10-2005, 09:03 AM   #1
Thermostat
Where exactly is it located in my 97? Where the top radiator hoes goes into the block?
97conv6 is offline   Reply With Quote
Old 06-10-2005, 10:04 AM   #2
97Stallion's Avatar
yes, exactly!! It's actually going into your lower intake manifold.
Living one day at a time!
Old 06-10-2005, 10:27 AM   #3
Ok, next question, my stock thermo has a hole drilled in it with a little ball, (some sort of valve type thing), do I need that on my new one?
Old 06-10-2005, 12:16 PM   #4
S**T, it's leaking now, and I've reinstalled it 3 times and can't get it to stop leaking, please HELP!!!!
Old 06-10-2005, 12:44 PM   #5
Zim
You want to **** me?
Zim's Avatar
I was in the same situation... that little fugger is hard to get to stop. Go get some sort of gasket sealer and coat it with that. Remember not to torque it down too much otherwise youll crack the housing. I broke 3 housings trying to do this, its a PITA. Good luck.
I like toys
Old 06-10-2005, 12:50 PM   #6
I was a moron and didn't look how it was in when I yanked it out, does the gasket attach to the block or does the thermostat go in first then the gasket over it??? I got some RTV sealant too, think that should do it???
Old 06-10-2005, 01:00 PM   #7
Zim
Zim's Avatar
The tstat goes in first, then gasket over that. Put that sealant around the stat too... good luck man, i eventually caved and took it to ford after breaking those 3 housings.
I like toys
Old 06-10-2005, 01:03 PM   #8
Yikes, that's encouraging, thanks man!
Old 06-10-2005, 01:12 PM   #9
Zim
Zim's Avatar
be sure the copper thing is sticking out of the housing, so its going into your lower intake
I like toys
Old 06-10-2005, 02:02 PM   #10
Alright guys I got it in and all set without any leaks(so far), thanks for the help, good to know if there's a prob that someone can help. Kick Azz
Old 06-10-2005, 02:04 PM   #11
Yep I got it, thanks Zim
Old 06-10-2005, 03:10 PM   #12
Zim
Zim's Avatar
right on man... good work
I like toys
Old 06-10-2005, 07:25 PM   #13
NorwegianMustang's Avatar
Send a message via AIM to NorwegianMustang Send a message via MSN to NorwegianMustang Send a message via Yahoo to NorwegianMustang
You mean the thingie with the springs?
Mods: Magnapacks, BBK X-pipe with cats, BBK CAI, hood struts, KYB Shocks/Struts, Eibach Pro springs, SS Inserts, CDC Light bar, Chrome 17" Bullits with Nitto 555 and N2O with dual purge
NorwegianMustang is offline   Reply With Quote
Old 06-11-2005, 08:13 AM   #14
Zim
Zim's Avatar
yeah
I like toys
Old 06-11-2005, 08:39 AM   #15
christ it's not that hard...its a thermostat...
I hope you guys weren't jsut using the paper filter and expecting that to seal?
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 06-11-2005, 09:19 AM   #16
Zim
Zim's Avatar
Its not hard, its just a pain in the ***... getting that ****er to seal is the hardest part. That and making sure you dont torque down too much on that housing and crack it... that was my problem.
I like toys
Old 06-12-2005, 04:55 PM   #17
Got another ? related to this. If you remover the tstat all together you would have constant flow through the engine, thus resulting in a cooler engine??? Please correct me if IM totally wrong on this, it's just a thought I had today
Old 06-12-2005, 05:10 PM   #18
It will run hotter, since the coolant wont get cooled enough in the radiator before it returns to the engine.
Old 06-13-2005, 06:41 PM   #19
gotch ya
Thermostat stuck open ?? duals 1996-2004 Mustang GT 2 09-08-2008 12:08 AM
Need help replacing thermostat floridamba Pre-2005 V6 Mustang 1 04-01-2007 06:30 PM
thermostat? ryanxup Pre-2005 V6 Mustang 3 11-27-2006 08:17 AM
thermostat housing Warfire80 1996-2004 Mustang GT 14 09-16-2004 11:00 AM
Thermostat Laser02 Pre-2005 V6 Mustang 14 07-08-2004 02:08 AM
05:29 PM
