My 2.3 - Mustang Evolution
Old 06-11-2005, 09:22 AM   #1
My 2.3
Could anyone tell me where to go and what parts i would need to hook my 2.3 up. I know its not a good idea, but its my little car to have fun with before i leave for the military.
Logik225 is offline   Reply With Quote
Old 06-11-2005, 09:22 AM   #2
Zim
You want to **** me?
Zim's Avatar
What do you mean hook it up? Get it running or modifying it?
I like toys
Old 06-11-2005, 09:28 AM   #3
Modifying it
Old 06-11-2005, 09:29 AM   #4
turbo it, thats the best way. Google 2.3L turbo and you will find a good bit...they have ran 9s before so you can have alot of fun.
Old 06-11-2005, 09:37 AM   #5
Zim
Zim's Avatar
:yup: SVO did great things with the 2.3T. I dont know what was done to the motor as far as the bottom end and stuff, but those cars have been known to be quite quick.
I like toys
Old 06-11-2005, 10:38 AM   #6
alright thats cool, thanks guys, and if theres anyhting else thatll pump this thing up, tell me
Old 06-11-2005, 10:53 AM   #7
Tbird232ci's Avatar
well, turbo'ing it is no easy task, because the factory 2.3L engines are build specifically for it, the heads are a bit differnet, the pistons are forged, and dished for 8.1:1 compression, the blocks have a bung for the oil return for the turbo, theres quite a few differences
just to mod it a bit, you can easily do basic mods, intake, exhaust, ignition timing (depending on year), gears, and things like that
what year is the car, automatic of 5-speed? some more details and i should be able to help more
my friend does have a chip for a 2.3L stang he's looking to sell, ill see what he wants for it also
Old 06-11-2005, 10:58 AM   #8
Its an 89 5 speed, thats what i plan to add was a cold ai intake with a new exhaust and ignition system, its just finding the items is whats getting me.
Old 06-11-2005, 11:13 AM   #9
Zim
Zim's Avatar
Im sure MSD makes an ignition system that will work for you... as far as CAI's and stuff, I wanna say that RGR has at one point custom made a CAI for a 2.3L. Id try PMing him and see if he knows anything about them...
I like toys
Old 06-11-2005, 11:18 AM   #10
who is RGR?
Old 06-11-2005, 12:14 PM   #11
bbunt302's Avatar
If you have experience with swapping engines and a little bit of wiring know-how, I'd recommend swapping in a 2.3 Turbo engine from another car (SVO, Turo Coupe, or some Mercurys). These engines can be found quite cheap and with a rebuild on the turbo can be quite reliable. You could probably get the complete engine for $500-600, which is about how much you'll spend on some of the mods others have recommended.
But if you don't feel comfortable doing the work yourself, the basic mods such as exhaust, gears, ud pulleys and CAI are going to be your best bet. Just don't expect huge gains out of the 2.3, especially if it's pre-91.
Scary stuff.
Old 06-12-2005, 09:24 AM   #12
Tbird232ci's Avatar
ill try to get the info on the chip my friend has, its a Diablo Sport for a 2.3L, but sometime in the run, they swapped to a DIS system, so not all the chips work for all years
if you look around ebay, you might be able to find a header for the car, a few years back (probably quite a few), there was a long tube header available
as for the cold air intake, it wouldnt be hard to make, since most of it is a straight shot to the fender, and i dont think that year was a MAF setup
you oculd always get into porting, and things like that too
Old 06-12-2005, 09:57 AM   #13
Bane-'s Avatar
id say swap in a turbo coupe or xr7 motor, then start porting/polishing and all that fun stuff.
tbird 89 was the 1st year for maf, my car missed it by like 3weeks
Old 06-12-2005, 07:51 PM   #14
Tbird232ci's Avatar
4 bangers are a different case
Old 06-14-2005, 05:50 PM   #15
I think ill just get a new clutch, new exhaust, new air intake, and ignition system for now. Just gotta find em, or build em myself. And is it also true that mustang 5.0 or GT parts will fi a 2.3L?
Old 06-19-2005, 05:06 PM   #16
bbunt302's Avatar
A lot of 5.0 parts will fit a 2.3 but it just depends on what parts your talking about. As far as I know nothing engine related is interchangeable. However, many of the suspension / brake parts will probably swap over, at least with a little work.
Scary stuff.
Old 10-17-2005, 08:21 PM   #17
Region: Iowa
Re: My 2.3
I have been there with the 2.3 NA engine and it is not fun, well not as fun as the turbo 2.3http://www.turbotbird.com/
http://projecthp.ford23.com/turboswap2.html
http://turboford.org
If any of these links dont work, forgive me, I suck at teh intraweb. The turbo 2.3 is a lot of fun, but I spent quite a while looking for parts in IA and was only able to find 85 and 86 Tbird TurboCoupe stuff.
The main difference between the turbo 2.3 and the NA 2.3 is the forged and dished pistons of the turbo engine, the larger combustion chambers, sodium filled exhaust valves (I have only read rumors and speculation on that), and a higher nickel content in the actual cast iron alloy that makes the block(more rumors and speculation, but makes sense). the turbo engines also had an extra hole drilled and tapped for the turbo oil return.
As far as parts go, you could tap the turbo oil return into your oil pan(above the oil level), put some turbo slugs in there, and that should be ready. I have been running a NA (1990) head in mine for about a year now and she does pretty well.
I think I read that your car is an 87, that is good news for you as you will read the computer requires very few pins to be moved in this case. you will just have to make a harness for the Vane Air Meter.
This swap is very much worth the effort, it provides plenty of power, the legendary 2.3Lima reliability, a cool whistling noisek: ,good fuel mileage (I could get more than 26 mpg if I could stay out of the boost) and most improtantly, plenty of enjoyment while doing this :drive:
Seriouslty though, spend a while pouring through those sites, and do some research before attempting the swap, doing something like this nets you a new awareness of your automobile.
Until you do the swap though there are always things like the Ranger header, Ranger roller cam (running one in my turbo engine, these do not wear out), and cutting the bottom off your air boz and gutting the air tube. The most expensive of these (cam swap for most) should still be less than $100.
1990 Mustang LX 2.3Turbo
Turbo Swap, 5-Speed Swap,Adjustable Boost valve(set at 15psi), Walbro 255lph(high pressure) fuel pump, 35# Injectors, Garrett T-3 Turbocharger(.60/.63)
4sd4d is offline   Reply With Quote
Old 10-17-2005, 09:15 PM   #18
Tbird232ci's Avatar
Re: My 2.3
I believe the rods in the turbo engines are also quite a bit stronger. The exhaust valves are hardened, and able to withstand the higher combustion temperatures, but im not sure exactly what makes them different, and the blocks are the same minus the oil drain back
Old 10-18-2005, 02:26 PM   #19
Region: Iowa
Re: My 2.3
^^I hadn't read any hard info on the valves, but I swapped them over into my head anyways.
And I had always been skeptical over the whole"more nickel content" turbo blocks.
11:38 PM
