Alignment problem - Mustang Evolution
Old 06-11-2005, 11:22 AM   #1
stang-rookie's Avatar
Alignment problem
Got new wheels and tires put on my car a few weeks back (from 15in to 17 in-255's front & 285's in back) and now it won't seem to stay aligned.I had it done when the new tires where put on and again 2 days ago. It seems to drive good for only a few miles then streeing wheel shakes and it throws me around pretty bad when i hit bumps in the road. Any ideas?
stang-rookie is offline   Reply With Quote
Old 06-11-2005, 11:28 AM   #2
having more bump steer is normal when going from 15s to 17s, are your roads really bad? My 275's all around dont give me any problems. Does the steering wheel shake bad or does the car just seem to follow the grooves in the road?
Raising the air pressure may help , but I wont go above 34psi on my 275s. There is a bumpsteer kit that is supposed to help the bumps taking you off course, steeda makes it.
Old 06-11-2005, 11:29 AM   #3
I liek gramer
WhiteStang99's Avatar
Have you done anything with lowering springs?
I'd check and maybe have the tires individually rebalanced. One of the wheels could be warped as well..
Old 06-11-2005, 11:33 AM   #4
if the wheels shakes its the balance of the wheels
Old 06-11-2005, 11:39 AM   #5
I haven't done any lowering, everything is stock, got the wheels from Stage 3 motorsports, wouldn't the shop have noticed if one of them was warped when they balanced them in the first place?
Old 06-11-2005, 11:40 PM   #6
im guessing the tire balance was done wrong
Old 06-12-2005, 07:16 AM   #7
Matt'sredbeauty's Avatar
Just asking but, what would be the problem if the tires seemed to follow the groves in the road, mine does this everynow and then, seems to be in one spot especially. Thanks
Matt'sredbeauty is offline   Reply With Quote
Old 06-12-2005, 09:00 AM   #8
Danger Dude's Avatar
Larger tires tend to drift more with the lines in the road, This is normal
Old 06-12-2005, 10:31 AM   #9
97Stallion's Avatar
Right but the shaking isn't. I would get your wheels rebalanced.
Living one day at a time!
Old 06-12-2005, 10:37 AM   #10
Actually it could also be his rotors. Worn rotors account for more shaking than anthing else except warped or tires that are not round from the factory. The last Goodyears I had was several years ago on my last Z-28. I went back 5 times before I told them to take them off and give me Goodrich tires. They went thru 3 sets of Goodyear Gatorbacks and they were all out of round. The other options are worn tie rod ends or ball joints
Old 06-13-2005, 08:01 AM   #11
Turns out there are adjustable plates for the struts and the left side needed adjusting. Ever heard of that? Anyway car seems to drive fine now. Thanks for all the input.
Old 06-13-2005, 08:54 AM   #12
yep thats part of setting the camber right.
Old 06-13-2005, 03:59 PM   #13
the stock plates are not adjustable really.. they just bolt up for the most part, do you have aftermarket plates?
Old 06-14-2005, 08:35 AM   #14
I think the plates are stock. The guy had to remove two rivets, then loosened a couple of bolts. He turned the plate, looked at the machine a couple of times, tightened the bolts down, and said "that should do it". He did tell me it looks like someone adjusted the other side also because the rivets were gone.
Rear alignment? Foxone General Mustang Discussion 3 12-13-2008 10:52 PM
alignment points gearbanger67 Classic Mustangs 3 06-15-2007 08:09 AM
Alignment Issues bodavenport 1996-2004 Mustang GT 4 12-08-2006 12:45 PM
frame alignment Dark02Pony Pre-2005 V6 Mustang 13 12-20-2005 10:12 AM
alignment question BlueDonkey Pre-2005 V6 Mustang 5 02-28-2004 08:17 PM
04:14 PM
