Intake Manifold issue "stuck open" - Mustang Evolution
Old 09-03-2009, 06:45 PM   #1
bigebobo's Avatar
My check engine soon light came on today on my v6 2004 mustang and I went to have it checked out and the computer reading said my intake manifold was stuck open. I was wondering if this meant i needed to have it replaced or what? Also, will it hurt the car if I continue to drive with the issue until I can get it into the shop? Any input would help! Thanks
bigebobo is offline   Reply With Quote
Old 09-03-2009, 08:55 PM   #2
Re: Intake Manifold issue "stuck open"
Any way you can give us the code number? Something doesn't sound right about that diagnosis...
Old 09-04-2009, 08:28 AM   #3
bigebobo's Avatar
Error code p2004
Old 09-04-2009, 06:13 PM   #4
Ok, that code is indicating your ECU is reading the IMRC's are stuck open. It might just be a bad switch or might be actually stuck open. Really...the only way to find out what is going on is to pull the intake and physically look, not fun I know.
It should be ok to drive it until you get it looked at, but I would highly recommend getting this looked at sometime soon.
One thing you might could try is to run some seafoam through the intake and see if it might clear up any problems.
Here's a discussion on the same code on a ranger:
Dtc P2004 - Ford Truck Enthusiasts Forums
And another breakdown for you:
http://ww2.justanswer.com/uploads/sn...5208_p2004.pdf
Old 09-05-2009, 08:40 PM   #5
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
The IMRC butterflies being stuck open won't hurt anything. The 99 and 00 6ers don't even have them and if you get the intakes ported, they remove them anyway.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 09-07-2009, 01:18 AM   #6
rinfield2004's Avatar
Yeah, my IMRC defaulted closed. didn't find out it died till I got it on the dyno. Come to find out this is common problem on our generation V6 mustangs. So, to re-enforce what "Horse" said. No, it won't hurt anything. Matter in fact, you're better off without it.
~2001 Mustang V6 Supercharged (10psi)~
rinfield2004 is offline   Reply With Quote
Thermostat stuck open ?? duals 1996-2004 Mustang GT 2 09-08-2008 12:08 AM
MTI RACING "Extreme Velocity" 454 "Southern Stingray" C6/Z = Awesome JROC Pictures and Videos 10 10-26-2007 03:33 AM
1995 Cobra "Fuel or Exhaust Issue" one95cobra 1979-1995 Mustang GT 9 11-05-2006 12:20 AM
w0000ttt!!!!! got something today (starts with "s" ends with "upercharger") fast64 Pictures and Videos 37 02-22-2005 05:52 PM
03:09 PM
