Painting engine block... - Mustang Evolution
Old 06-12-2005, 07:02 PM   #1
Do you have to buy a special primer to coat before spraying the engine block or does the paint have some kind of rust resitant in it already to prevent rust from eating through the paint.
Old 06-12-2005, 07:07 PM   #2
bbunt302's Avatar
Just get some engine enamel and spray it, no primer needed. Mine still looks just as good as it did when I painted it after a year of daily driving. Just be sure to do a really good job of taping everything up or you'll have to hone out the cylinder walls again.
Scary stuff.
Old 06-12-2005, 07:09 PM   #3
Danger Dude's Avatar
I have painted hundreds. When you get the engine back from the machine shop it will have been vatted and be ready for painting. Just get some engine color of your choice and paint it on the engine stand.
I am puzzled why you have not asked about this before. I would go with a aluminum or dark green color to offset the valve covers
Old 06-12-2005, 07:23 PM   #4
take your time and do a few light coats and let dry fully then have at it, no mystery
Old 06-12-2005, 07:32 PM   #5
97Stallion's Avatar
no need to do light coats. It's not like you're really going to see the engine block that well. I painted mine ford blue and I can see it very little.
Living one day at a time!
Old 06-12-2005, 07:40 PM   #6
But while it is on the stand it will look bad ***
Old 06-12-2005, 07:56 PM   #7
Ponycarman's Avatar
Like any paint job the prep is the key.
If there is rust on the block when you paint it then it will come thru the paint eventually.
If there is oil or other contaminates on the block it will affect the paint.
For years and dozens of engines I never used a primer, till my last engine. I used Rustoleum's oily machinery primer and for the color coat I merely find a color I like at Lowe's and paint it with that, no it's not an engine enamel. This is the best paint job I have ever had. Both in appearance and durability.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 06-12-2005, 08:46 PM   #8
Steve
It is being vatted so there will be a clean block and like everyone said light coats and allow to dry for a a few hours between coats. The fatal mistake in painting is not allowing each coat to properly dry. so when you you spray thwe next coat to soon it disbonds from the block cause it never fyully drys and it will peel.
Old 06-13-2005, 06:24 AM   #9
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
paint it plaid
:pnoid:
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 06-13-2005, 10:07 AM   #10
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Jets engines dont count Corey
Rellik is offline   Reply With Quote
Old 06-13-2005, 11:10 AM   #11
Dude you cannot paint turbine engines and why would you paint titanium, aluminum alloy
Oh I forgot a racers trick. Paint the lifter valley to expedite the oils return to the crankcase
Old 06-13-2005, 12:03 PM   #12
Bane-'s Avatar
eastwood sells a kit for ur engine with plugs that just screw in where everything else would so you dont have to take forever in taping it off. might wanna check into that aswell.
Old 06-14-2005, 07:39 PM   #13
Region: New Hampshire
Send a message via AIM to Smokedya95stang
I was curious about something too. I want to paint my 302 and i've seen people sand the whole block (duh) but they also bondo. Wouldnt the bondo heat up and crack?
-Charles
Smokedya95stang is offline   Reply With Quote
Old 06-14-2005, 08:22 PM   #14
Ponycarman's Avatar
Don't know too many vat jobs that take off rust anymore. Used to be they did but the good old EPA f'ed that up.
Steve
1996 Mustang
1965 Barracuda
Old 06-14-2005, 08:23 PM   #15
Ponycarman's Avatar
Don't use just any old paint, it'll flake off inthe hot oil and f up your oil pump.
Glyptol or rustoleum oil machinery paint is th eticket for that.
Steve
1996 Mustang
1965 Barracuda
Old 06-14-2005, 09:02 PM   #16
97Stallion's Avatar
Yes the bondo will eventually crack and fall off.
Old 06-14-2005, 09:45 PM   #17
Steve
No I only used green Rustoleum machinery paint. Been doing it for 20 +years and never once found any paint in the oil filter or inside the engine
Old 06-14-2005, 09:46 PM   #18
Were they using Bondo or JB weld. JB weld will not crack off and I have seen it used before but that is really anal for something that really wont be seen
Old 06-15-2005, 08:26 AM   #19
I use VHT high temp self etching primer and VHT Engine enamel. Glyptol in the valey and in the timing area.
Works well methinks.
96 GT 4.6 L
Ported 2004 Upper Plenum
B&M Shifter
Bassini O/R X Pipe
FRPP Adjustable Clutch Cable
UPR Extreme Triple Hook Quadrant
UPR Extreme Firewall Adjuster
Ford 11"Clutch Conversion
C&L MAF
WMS CAI
Aluminum Drive Shaft
95 V6 Vert: 4.2L swap, Trac Lock, Light Cam, Mac Shrorty Headers, More to come.
AlmostN8 is offline   Reply With Quote
Old 06-15-2005, 08:29 AM   #20
Damn I did forget to mention the timing chain area!!!
Old 06-15-2005, 06:45 PM   #21
They def sanded on bondo. lol
-Charles
Old 03-19-2010, 12:18 PM   #22
upton7's Avatar
Re: Painting engine block...
how many coats should it normally take? (googled painting engine blocks and ME came up lol)
Old 03-20-2010, 08:52 PM   #23
Wow... way to bring back a 5 year old thread
Old 03-20-2010, 09:26 PM   #24
Zebs5408's Avatar
LOL dang bro it really is 5 years old lol...i bet NO ONE noticed that...if u would have said anything i would have thrown my 2 cents in......welll screw it im gonna do it anyway...prep and degrease it in FINE DETAIL....I CANT STRESS HOW MUCH DETAIL then go POWDER COAT IT....im pretty sure you have completed this project by now or your worse than i am lol! God bless brotha
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 03-22-2010, 07:32 AM   #25
thread closed, make a NEW thread dont bring back super old threads... there is even a check box that says "are you sure you want to bring back a super old thread" or something similar....
Help IDing this engine block! kurtisp777 1979-1995 Mustang GT 1 06-08-2008 02:51 PM
wanted 289 block/engine poboy427 Classic Mustangs 1 09-18-2007 07:21 PM
Help With Painting Engine Pieces PureVenom Mustang Audio & Video 17 07-29-2005 05:55 PM
» Members Mustangs
Sal
KSN95
DD #2
87LX306
Add your Mustang
08:30 AM
