Strange noise....fuel pump? - Mustang Evolution
Old 06-16-2005, 08:46 AM   #1
My '96 v6 has a mid to high frequency humming noise that runs non-stop.It actually changes pitch a bit if you use any of the controls such as power windows,or turn signals ect.
A guy at work said its the fuel pump and that its quite common on Fords from 1996.The car runs fine with no problems but the sound is getting on my nerves.
Any ideas or suggestions???
2001 Cobra Mineral Grey
Manual trans
Ghostbuster is offline   Reply With Quote
Old 06-16-2005, 12:54 PM   #2
I liek gramer
WhiteStang99's Avatar
Well using the power windows or turn signals changes the electrical needs of your car, so it usually increases the RPMs slightly.
My suggestion is to take off your belt and spin all the pulleys by hand, find the one that makes a different noise. If it makes a noise when you hand spin it, think about the noise it'll be making at 2,500 RPMs.
Old 06-16-2005, 01:08 PM   #3
Danger Dude's Avatar
Where is the hum coming from the back or front of car???
Old 06-16-2005, 01:24 PM   #4
It does seem to be coming from the rear.
Manual trans
Old 06-16-2005, 01:31 PM   #5
Then messing with your pulley's wont do a thing. If it is continously running you either have a pump that is clogged or inside the tank or the pump is going out. I tis probably not the fuel filter because if it was clogged the car would have starvation problems
Old 06-16-2005, 01:36 PM   #6
It has no problem at all getting fuel,starts right up,no hesitation,runs well.
The noise does run non-stop.The fellow at work said it may quit tomorrow-might run like this for years....I don't find much comfort in that.
Manual trans
Old 06-16-2005, 04:29 PM   #7
hmmm, the fuel pump can be heard with out the car running if you turn the key to on with out cranking the car, it will click on, listen for it and see if thats the noise, it dont last long so listen close.
it may just be loud, or going out and making more noise, when you pull power by rolling up the windows at idle it may strain the pump a little bit not getting all the power it needs and making it die down... but I wouldnt think so. Your battery may be going bad? do you have an UDP?
Old 06-16-2005, 04:56 PM   #8
97Stallion's Avatar
Their's no ned to worry, it's your fuel pump. I have the same thing on my car. That's all it is.
Living one day at a time!
Old 06-16-2005, 07:11 PM   #9
MonteCitan's Avatar
better yet start and run your car without the belt on, if the noise goes away you know its an accessory.. if it stays you know for sure its the fuel pump..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-16-2005, 10:36 PM   #10
Kiljosh's Avatar
Bad idea. Your water pump wouldnt be moving colant that way. I guess it wouldnt hurt much if it was only quickly. :dunno:
Old 06-17-2005, 10:02 AM   #11
Does this mean its on the way to failure?Or....more just a quirk of the pump?
Manual trans
Old 06-17-2005, 10:18 AM   #12
Ponycarman's Avatar
My 96 has the fuel pump noise. Pull the gas cap and listen, is the nosie louder there? If so there you go. I've probably put 40k miles on it since I bought it and the pump has always made that noise. And no it's not a plugged filter or pump either.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 06-17-2005, 12:01 PM   #13
Steve
Thanks.I think I'll just drive it, runs fine.
Manual trans
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 04:22 PM
strange clutch noise R1CK3R Pre-2005 V6 Mustang 10 10-02-2009 11:47 PM
fuel pump?? Xx_1990GT_xX 1979-1995 Mustang GT 7 10-07-2008 07:37 AM
Strange Noise HELP 19ClearCobra96 1996-2004 Mustang GT 10 09-26-2005 02:29 AM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-12-2005 12:04 AM
02:58 PM
