spark plugs and wires - Mustang Evolution
Old 06-19-2005, 09:20 AM   #1
Do different spark plugs and spark plug wires make any kind of difference on a car with few modifications such as mine? Thanks.
cms09071987 is offline   Reply With Quote
Old 06-19-2005, 09:57 AM   #2
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
with mustangs you do NOT want to use plugs like bosch platnum ( single +2 +4 ) or any of those just use motorcraft or autolites. i had bosch platnum 2 plugs in my mustang and took them out after 2 days it made the c ar run horrible. bought autolite platnums and no problems what so ever
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 06-19-2005, 10:49 AM   #3
what have you guys heard of NGK IX spark plugs. the iridium plugs. i know they are a bit expensive for plugs but how do they perform?
bigpomps is offline   Reply With Quote
Old 06-19-2005, 11:04 AM   #4
97Stallion's Avatar
I would suggest using Autolites or Motorcraft plugs. I personally have not seen any sort of gain with bigger wires or any kind of special spark plug. The only reason people check out their wires is ensure a good clean, powerful spark to the cylinder. The factory wires are good enough for a while, but over time become weak and brittle and do not provide a good conductive path anymore. Thicker wires are the same way, they just take longer to break down.
Living one day at a time!
Old 06-19-2005, 01:12 PM   #5
bbunt302's Avatar
I agree. Don't waste your money on expensive spark plugs because you will not notice any difference. You can pick a set of Autolites up at Walmart for 5 bucks compared to whatever insane amount the NGK's cost (I was thinking it was somewhere around $40 for 8). The only performance increase you may notice from new plugs and wires will be if there was something wrong with the old ones.
However, be sure the new plugs are gapped correctly. An incorrect plug gap can cause a lot of problems...
Scary stuff.
Old 06-19-2005, 01:26 PM   #6
Rick0636's Avatar
Yeah, I put a set of Bosch Platinum plugs in an old Pinto 2.3L one time, it ate them up, I mean burnt the electrodes right out of them in a few months. Just use Autolites or Motorcraft in your ford, I remember a chevy guy telling me one time he only ran Autolites in his Camaro, lol.
Plugs & Wires ?? wvstang5.0ho 1979-1995 Mustang GT 5 07-13-2008 11:11 PM
new plugs and wires meteorachick Pre-2005 V6 Mustang 12 12-04-2007 08:05 AM
Need help with spark plugs and wires! 1sweet6 Pre-2005 V6 Mustang 21 02-06-2006 12:04 AM
spark plug wires... which one? electricstang Pre-2005 V6 Mustang 6 09-15-2005 02:19 PM
spark plugs and wires romeoz Pre-2005 V6 Mustang 11 10-25-2004 02:23 PM
11:57 PM
