Rear brake locks up again ???? surprise finding - Mustang Evolution
Old 06-20-2005, 05:37 AM   #1
Danger Dude's Avatar
So I am really getting on it on some very curve back roads having a blast. I had this Focus, dont know why model simply because he only saw my rear tail lights getting smaller, up on my bumper when I got to the first S turn.I was originally going to take it easy on the first turn but realizing he was wanting to play I let the hammer down and I obliterated him pulled several car coming out of each corner when I came to the first long straight away he was well over 100yds behind me and when I got thru the all the curves I stop and pulled off the road waiting for him. I rolled down the window and smelt the brake again. I got out and smoke rising from the caliper. DAMN!!!! So I wait a while for it to cool. It is only the left side the right was fine. I get back home and take the brake apart and go get another caliper and rotor. I get it installed and go for a test cruise. I get up on the interstate and when I get off the brake is hot again. DOUBLE DAMN. I get home and take it apart and while I am inspecting everything I come across my problem . My axle is loose. It has roughly 3/16 play pulling and pushing on it. I put the brakes back together and pull and push on the rotor. Damn when I pull on it the outer rotor surface hits the outer brake bracket that holds the outer pad in place. TRIPLE DAMN. Now I have either a bad axle or bad bearings.
So I am spending my leather seat money on the damn rearend. This sux!!!
Old 06-20-2005, 05:46 AM   #2
Monkey's Avatar
bummer dude. that sucks.
Old 06-20-2005, 06:50 AM   #3
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
damn, that's no good
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 06-20-2005, 09:42 AM   #4
time to build an 8.8
Old 06-20-2005, 12:26 PM   #5
I liek gramer
WhiteStang99's Avatar
That sucks a lot. Sorry to hear Corey...
Old 06-20-2005, 02:13 PM   #6
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
o man that hurts, sorry to hear that. good luck, with fixing it.
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 06-20-2005, 03:26 PM   #7
Ponycarman's Avatar
STOP!
DO NOT DRIVE YOUR CAR.
The C clip that holds the axle in place IS MISSING. the only thing keeping your axle shaft in the car is the caliper, if you had drums the axle shaft would be gone.
STOP!
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 06-20-2005, 04:07 PM   #8
Monkey's Avatar
^^ that's what I was thinking, but it could also be a loose caliper bracket. The axle should have a little play in it.
Plus, if a c-clip fell out, then he would have really chewed up gears and posi. Metal floating in the pumpkin would only get into the ring and pinion set and cause more damage.
Old 06-20-2005, 04:29 PM   #9
Originally Posted by Ponycarman
STOP!
STOP!
This public service announcment is brought to you by Ponycarman.
All rights reserved.
Ponycarman is not affiliated with Mustangevolution.com and we can not be held liable for any damage occured do to advice taken and/or not taken.
Old 06-20-2005, 07:02 PM   #10
Urgent Urgent!!!!!!
I am not driving it!!! I know it is not the Calipers because I bought a new one and they are tight on the mount bracket attached to the axle housing.
Now that I think about it I tried pulling with all my might to get the axle to come out when I had the brake assembly off.
Old 06-20-2005, 07:27 PM   #11
slvr2000stang's Avatar
That sucks Corey.
Good luck & keep us posted.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 06-21-2005, 06:36 PM   #12
Found the source of the problem. Differential is bad. It needs a rebuild or I need a new one. Something behind the spider gear that the left rear axle shaft slides thru is worn or compressed. So I am at a dilemma as to what to do??? Do I buy new or rebuild
Old 06-21-2005, 06:57 PM   #13
Dang..I missed all this...
Old 06-21-2005, 07:09 PM   #14
Zim
You want to **** me?
Zim's Avatar
buy me a cheap stock one and Ill give you mine with 4.10s and tlok already installed.
I like toys
Old 06-21-2005, 07:25 PM   #15
PM coming in to you
Old 06-21-2005, 07:33 PM   #16
Ponycarman's Avatar
Sounds like the C clip to me.
Steve
1996 Mustang
1965 Barracuda
Old 06-21-2005, 07:38 PM   #17
Steve
Dude I have taken the old C clip out installed the new clip in and nothing. still slops 3/16. I took the other side out and checked it the Shaft is OK. Where I have the problem is in the spider gear is recessed do to the wearing of the clutches or thrust washer. That spider has buggered up teeth from it actually not meshing correctly
Old 06-21-2005, 09:36 PM   #18
Tbird232ci's Avatar
its the c-clip
just messin with ya
Old 06-21-2005, 09:45 PM   #19
Zim
Zim's Avatar
Nice talkin to ya Corey :thumbs2:
I like toys
Old 06-21-2005, 09:46 PM   #20
Monkey's Avatar
junkyard 8.8 with eaton or auburn posi and some 4.30s or lower
Old 06-21-2005, 10:07 PM   #21
No it will be a new 7.5 from GEF unless one of our sponsors will match GEF at 169.95 shipped for a new T Lok.
Old 06-21-2005, 10:27 PM   #22
Corey,
What are you looking to get?
What do you need?
2000 Vert 4R70W
Old 06-21-2005, 10:34 PM   #23
A 7.5 T Lok by Thursday
Old 06-22-2005, 08:43 AM   #24
Ponycarman's Avatar
Ah, I thought you had ruled out the spider gear in a prior post. Might want to make doubly sure the end of the axle shaft isn't chingered up from the slop too.
Steve
1996 Mustang
1965 Barracuda
Old 06-22-2005, 10:02 AM   #25
Steve
No I gave the spider gears a look over with limited light and still oily when I went in the first time to see what was going on. I went back in last night and cleaned everything and took a bright light and a mirror to do investigations
Old 06-22-2005, 10:04 AM   #26
Ok, No t-lok here just a stock open diff.
2000 Vert 4R70W
Old 06-22-2005, 10:12 AM   #27
I have a open diff I could use but I aint gonna do it.
Old 06-22-2005, 10:36 AM   #28
I would not either.
2000 Vert 4R70W
Old 06-22-2005, 11:12 AM   #29
Just got a T-Lok from West Coast Differentials being shipped, be here tomorrow. Almost everyone is on backorder on these except them.
Old 06-22-2005, 11:43 AM   #30
glad you found one
2000 Vert 4R70W
Old 06-22-2005, 03:05 PM   #31
I actually think I have a similar problem.
My rear driverside wheel pops when I take turns sorta slow. I'm afraid that something is loose or broken with either the brake or the axle/diff.
When I finally get around to changing my rear diff fluid I'll check around in there and see if anythings wrong.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 06-23-2005, 05:31 PM   #32
97Stallion's Avatar
Or Corey, if you wanna come down to Sumter and help me install my 8.8 on to my car you can have my old 7.5 for free
Living one day at a time!
Old 06-23-2005, 07:15 PM   #33
Actually if you have my problem your rotor would bbe hitting the outer brake beacket that holds the outer pad in place.
You need to change your rear lube. The poping is a tell tale sign you need to change fluid. On T Lok's you need to change fluid every 12 to 18 months or it will pop in turns.
Old 06-23-2005, 07:17 PM   #34
Well I Thank you for the offer but as we discussed on the phone just 30 min ago I have a diff coming in tomorrow. That does not mean I wont come down and help you install your rear end though!!!
Old 06-26-2005, 08:19 PM   #35
Well here is an update. I installed my new T-Lok this afternoon. Really not to bad. The hardest thing was going to work and pressing in the new side bearings onto the differential. Being on your back working is a bit of a pain but all in all a nice day of working on my stang. Oh I forgot My kids gave me a Mr Clean autodry car wash system for Fathersday Woohoo
Took it for a ride all is good
painting rear brake drums trickflow211 1979-1995 Mustang GT 1 07-22-2008 09:07 PM
Rear brake caliper anchor bolt size/help CakeOrDeath? Pre-2005 V6 Mustang 5 09-01-2007 12:04 AM
Brake light coming on and rear end ridenmystang 1996-2004 Mustang GT 31 12-13-2006 01:07 PM
Rear brake seized Danger Dude Pre-2005 V6 Mustang 9 05-24-2005 09:11 PM
rear brake install question kevinsm Pre-2005 V6 Mustang 4 03-16-2004 10:01 AM
11:45 AM
