New Motor - Mustang Evolution
Old 06-20-2005, 03:23 PM   #1
New Motor
Well I am in the process of building a new motor ,ordered the pistons and rods from Tom today .The pistons will be a 10.5:1 C/R and the rods will be SCAT H-beams .
GT-Eater is offline   Reply With Quote
Old 06-20-2005, 03:30 PM   #2
make it 4.2
Old 06-20-2005, 03:32 PM   #3
I will do better then that how about a 4.3 LOL
Old 06-20-2005, 03:42 PM   #4
nice man, i always wondered why you had kept the 3.8 crank
Old 06-20-2005, 04:10 PM   #5
So there will be two 4.3's on the site then
Went and got my price for machining of my block and its 325 for everything I need including the .030 overbore.
Now just waiting on the rotating assembly to get here which I was hoping would be today.
Old 06-20-2005, 04:19 PM   #6
Monkey's Avatar
why do you need H-beam? Don't you think that's a little excessive? Most I-beams are good to around 600+hp.
EDIT: nevermind, I checked out your profile and saw what you were running. The H-beams will be good for ya
Old 06-20-2005, 04:35 PM   #7
Yeah they will work ,Plus with these rods you don't have to touch the crank they will clearence without any massaging the crank so it stays stronger .
Brent I'm going .40 over What C/R are you running ? Also are you getting your pistons coated?
Old 06-20-2005, 07:01 PM   #8
I believe its going to be 10:1 or right there near it.
Nah not getting the pistons coated I am on a deadline to get this done before I leave for vacation July 18th and I am tight on money. Plus I dont have the money to throw boost at it for awhile.
Old 06-20-2005, 07:12 PM   #9
I liek gramer
WhiteStang99's Avatar
^ werd. we're starting tomorrow right.
Old 06-22-2005, 10:19 PM   #10
Confirmed 10:1 compression ratio
Old 06-22-2005, 10:27 PM   #11
Saweet ,I would have like to go that high but I was Sceeerrrreed to run that high with 20psi and Nitrous
Old 06-22-2005, 10:35 PM   #12
Yea my power adder is two years down the road atleast unless money just falls into my lap soon... lol.. I wanted a nice N/A beast until then
Old 06-23-2005, 07:45 AM   #13
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
^word, that's the way to go
i'm thinkin about scraping my turbo plans and just going all N/A, high compression and see where it lands
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 06-25-2005, 10:53 PM   #14
Send a message via AIM to tedness
i'd love to have a 4.3 but its not in the cards rite now.
so i'm probly gonna do a stage 2+ power back from super six motorsports.
a good 230rwhp v6 is plenty good for me. its very rarely gonna see the 1620 as it is because thats just a quick way to eat a motor.
tedness is offline   Reply With Quote
Old 07-04-2005, 09:42 AM   #15
Can you give me a website for that power pak you speak of??????
petrey10 is offline   Reply With Quote
Old 07-04-2005, 10:26 AM   #16
it's 1320
and I've got over 115 timeslips on my motor without any major problems. (knock on wood)
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 07-04-2005, 12:07 PM   #17
Kiljosh's Avatar
www.supersixmotorsports.com
also check out
www.rpm-mustangs.com
Both are great but RPM is cheaper, and basically the same thing.
Old 07-04-2005, 10:24 PM   #18
Sorry Man but i am just not seeing the Stage 2 power pak at RPM.... where is it located????sorry
Old 07-04-2005, 10:31 PM   #19
Tbird232ci's Avatar
Well I am in the process of building a new motor ,ordered the pistons and rods from Tom today .The pistons will be a 9.5 C/R and the rods will be SCAT H-beams .
im curious to know why youre going as high as 9.5:1
in the 2.3L cars (i know its not a 3.8/4.2, but its what i know), most poeple who run 9.5:1 have problems with detonation, and are limited to about 12psi on pump gas
the 2.3 turbo cars came with 8.1:1, and thats usually good for 28-30psi on pump gas, as long as youre running a nice intercooler, and not overspinning the turbo and creating exessive heat
even the 2.2L chryslers run 8.1:1 if i remember correctly, and they have cast pistons
Old 07-04-2005, 11:39 PM   #20
I can get away with it because it's not a daily driver I have converted it to an all out track car .I run 118 octane so detonation is not a problem.
Old 07-07-2005, 11:09 AM   #21
Tbird232ci's Avatar
race gas makes all the difference
going to run alcohol injection or anything as a safegaurd?
Old 07-07-2005, 02:44 PM   #22
No I'm going to run a 75 shot to cool the charge ,and kick her in the butt.
Old 07-08-2005, 12:44 AM   #23
Tbird232ci's Avatar
good intercooler?
Old 07-08-2005, 08:40 AM   #24
Well the nitrous is my intercooler ,at -232* below zero it's pretty effective .
It helps in two ways It gives me a more low end torque down low and cools the charged air on the high end where the intake air temps would be getting pretty high without it .
Old 07-08-2005, 09:03 AM   #25
slvr2000stang's Avatar
This is at supersix not RPM.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 07-12-2005, 12:11 PM   #26
10:1 LOOOOVES Nitrous.
96 GT 4.6 L
Ported 2004 Upper Plenum
B&M Shifter
Bassini O/R X Pipe
FRPP Adjustable Clutch Cable
UPR Extreme Triple Hook Quadrant
UPR Extreme Firewall Adjuster
Ford 11"Clutch Conversion
C&L MAF
WMS CAI
Aluminum Drive Shaft
95 V6 Vert: 4.2L swap, Trac Lock, Light Cam, Mac Shrorty Headers, More to come.
AlmostN8 is offline   Reply With Quote
Old 07-12-2005, 01:06 PM   #27
Old 07-12-2005, 05:57 PM   #28
Well it's going to get a boner on 10.5:1
Old 07-17-2005, 10:24 PM   #29
Send a message via AIM to hoof
Super Six Motorsports has the powerpacks. They built my motor, and there customer service is incredible. The only thing I got through RPM was a ported and polished upper, but they were really great to work with too. My motor is at 10to1 compression, and I am having a hard time getting pump gas to stop knocking.
CHAZ
hoof is offline   Reply With Quote
Old 07-17-2005, 11:02 PM   #30
Refresh my memory Hoof did you ever get tuned ? And I would assume you are running premium gas .
Old 07-18-2005, 12:01 AM   #31
Tbird232ci's Avatar
have you tried different gas stations? spark plug gap?
hot to tell the dif between PI motor and reg motor Keto77 1996-2004 Mustang GT 13 07-29-2009 12:03 AM
What motor.. bullitt482 General Car Discussion 55 02-23-2007 03:51 AM
What motor..... bullitt482 General Car Discussion 9 02-16-2007 04:44 PM
New Best On the Motor v6stanger Pre-2005 V6 Mustang 4 02-25-2006 08:04 PM
Motor coolstang Pre-2005 V6 Mustang 5 01-21-2005 09:19 AM
12:05 PM
