Supercharger worth it? - Mustang Evolution
Old 09-10-2009, 10:06 AM   #1
I recently found a thunderbird sc, The guy said i could get the supercharger,the lower intake, the thunderbird throttle body, the intercooler, the mounting brackets and tensioner pulleys for $300. Is it still worth trying to put it on my 99 v6? I know i would have to buy new radiator hoses and belts, and that u have to move some stuff around. hoses and belts $70. Would it be worth the time and money to swap? and would i need to do anything else?
mustangfan9969 is offline   Reply With Quote
Old 09-10-2009, 10:22 AM   #2
Re: Supercharger worth it?
To put it simply, it wont work. You will need basically the entire engine. It does not just bolt up to your car even though they are both 3.8L engines.
Many V6 guys/girls are going with a 2003/2004 Cobra mustang superchargers (M112) with adapter plates etc. The end result is about 280-300rwhp/tq over the stock 135-155 using about 10 psi. The kit will cost about 2,000-3,000 dollars (there about depending on what you do) and will require a custom dyno tune so add in another 1000 dollars.
The only down side to this is that it is not intercooled, which means hot compressed air goes right into your engine. Some say this is not an issue... but I bet if a good cooling solution came out they would be the first in line lol, plus heat robs power. The cobras use a water to air heat exchanger that the v6 can not due to space requirements.
Any supercharger kit will run you 3000 and up though.
Old 09-10-2009, 10:36 AM   #3
Thanks for your reply. I just dont have much money at all at the moment. but it will come along one day.
Old 09-10-2009, 12:19 PM   #4
Yea, plus keep in mind if you can afford to mod it be ready to afford to fix it and accept that it may happen. It all of course depends on the level of modding, dont put a supercharger on the car and hope its reliable enough for a daily driver for years to come or anything. It may be but dont rely on it~
Old 09-14-2009, 08:31 PM   #5
would the turbocharger be more "reliable"?
CAI with turbonator, Blk Cobra Rims(17x9frt, 10.5r), Plate BLKNES, Internal+external blue neons w/music interface, Blk MUSTANG letters r.bumper, Alpine Flip Out deck,(4 Rockford Fosgate 120RMS speakers, 4 way RF 600RMS Amp, 12" Audiopipe Sub 600RMS w/custom box, Mono Kicker 600RMS amp, kept mach tweeters), Blk Grille Mustang, Halo Headlights w/10K bulbs, SCT 9600, flowmaster dual exhaust. Soon to come; Short Throw Shifter, 3.73 gears with TLOK.
Blkness is offline   Reply With Quote
Old 09-14-2009, 11:25 PM   #6
You can make more HP with a Turbo, but remember it takes time for it to spool up and good luck with the piping on it.
19Delta is offline   Reply With Quote
Old 09-15-2009, 07:13 AM   #7
turbos are just as reliable but they have more parts and pipes but its not a big deal if you get a good kit
Old 09-15-2009, 09:35 AM   #8
Thats what i was thinking because i really don't want to get a supercharger for a v6 seems silly
Old 09-15-2009, 01:35 PM   #9
why would a s/c be any more silly than a t/c
ThaWill is offline   Reply With Quote
Old 09-15-2009, 02:42 PM   #10
4k for 280 rwhp over 150 stock or so not to bad~
Old 09-15-2009, 02:43 PM   #11
So I'll see at least 280 out of my s/c build?
Old 09-15-2009, 11:21 PM   #12
1st well for either. to spend 4 k for a mod. 2nd if you get more power with a t/c then why a s/c? 3rd buy a stage3
supercharger worth it? CHILE10_STANG Pre-2005 V6 Mustang 84 05-03-2010 04:12 PM
you think its worth it? Kyle The Bar 8 12-04-2006 08:58 PM
How much are YOU worth? bluemustang The Bar 60 01-30-2005 11:03 PM
worth it thirstymate The Bar 3 09-02-2004 08:20 PM
what's this worth? tire The Bar 0 01-26-2004 11:20 AM
03:48 AM
