How do you add a larger throttle body? - Mustang Evolution
Old 08-17-2003, 04:37 PM   #1
Add a CAI. That makes the throttle body the smallest (99+) opening. However, with only 3.8L does a 70mm realy make much sense? That's bigger than what allot of my friends run on 5.0's!
Women prefer good handling to quick rides!
gdcpony is offline   Reply With Quote
Old 08-17-2003, 09:45 PM   #2
Danger Dude's Avatar
stock 5.0 87 to 93 60mm. 94 -95 5.0 65mm
Old 08-20-2003, 10:38 PM   #3
Send a message via AIM to el cheapo
If you have a cai and ported intakes, then upgrading the maf and tb is prolly a good idea. Also if you run boost. Otherwise, dont get one.
damn it school, why do you suck so bad??
el cheapo is offline   Reply With Quote
Old 08-21-2003, 05:25 AM   #4
There is no reason to get a larger MAF unless you are going Supercharger. The stock MAF flows quite well for just about any N/A application or mod.
Old 08-21-2003, 10:19 AM   #5
Rick0636's Avatar
If you don't port the crossover point from the throttle body to the upper intake then its a bottle neck on the 94-98s, not sure on the 99+, I went with a 70mm on my 99 GT, you can get a 75mm for the 99GT, but its not recommended unless you are supercharging. So why would the V6 need as large a tbody as the 4.6 anyhow? I have heard that too large a tbody can reduce the velocity of incoming air and this is bad for your engine??
Old 08-21-2003, 11:36 PM   #6
Send a message via ICQ to TheSarge Send a message via AIM to TheSarge Send a message via Yahoo to TheSarge
Still....
9" x3" dia K&N filter, prom 75mm MAF, 3" CAI to a stock 52mm TB, and p/p intakes and heads, the TB and orifice is the bottleneck!!!
I have a 93 5.0 TB and I want to adapt it to my single port motor... what do I need to do? Do I need Flex's adaptor or can I redrill the TB myself? How do I adapt the linkage and TPS cable/cruise control?
GOt any pics of this?
God Bless Our Troops!
In search of the best mods for the least price.
I'm always broke, I work for Uncle Sam!
SEMPER FI!!
TheSarge is offline   Reply With Quote
Old 08-22-2003, 06:55 AM   #7
I have a 5.0 TB and it has elongated holes for fitment on the upper Intake manifold. you need to have a 94-98 TB Linkage welded to the 5.0. As far a the Throttle Position Sensor you need the 5.0 sensor and it has to be adapted or spliced into the stock TPS harness. I actually got Terry at Midwest to send me a section of a 5.0 wire harness and made a custome quick disconnect that left the stock wiring harness intact
Old 08-22-2003, 07:50 AM   #8
Pix?
SEMPER FI!!
Old 08-22-2003, 08:04 AM   #9
Pix !!!! And give away my super secret mods??????? I will get with Jeff this weekend and have him take pics
Old 08-22-2003, 08:48 AM   #10
Rick0636's Avatar
The flex adapter might be an "easier" route Corey's way might be very complicated Sarge, hehehe.
Old 08-22-2003, 08:56 AM   #11
Hey wait a minute To elongate the holes is complicated : : :
It might require 30 minutes of your time but it is cheaper to elongate the holes .
I am not saying dont buy Flex's adapter he has a quality product.
Oh and if you are looking for a TB here is one off a 90 Lx 5.0 it come with intakes but for $10 not a bad deal
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2428529637&category=36474
Old 08-22-2003, 09:02 AM   #12
Rick0636's Avatar
LOL, I was just messin' with you Corey, lol. Chill buddy...
Old 08-22-2003, 09:17 AM   #13
I know buddy You are allowed to mess with me
Old 08-22-2003, 09:40 AM   #14
Rick0636's Avatar
Corey, is your car running ok now, or you going to take it to Atlanta for a Fordchip dyno tune?
Old 08-22-2003, 10:50 AM   #15
Heres another thing...the back side of the TB isn't flat, but is undersut , how will the TB gasket seal?
And again, I am not sure how to build the linkage.. I can work iron well enough, just wondering what needs to be done.
To me, it looks like you can just adapt the linkage and TPS cable mount. AM I wrong? I've heard that the linkage needs to be converted from push to pull. Are there pics somewhere of an un mounted pic of an adapted TB?
SEMPER FI!!
Old 09-22-2003, 04:13 PM   #16
RGR
Send a message via AIM to RGR
Re: How do you add a larger throttle body?
Originally Posted by ASSEMbler
I was wondering how to add the 70mm throttle body? Is it a bold onto the intake manifold? So I have to make an adapter plate?
Also, will the new throttle interfere with the ECU? Will it run insanely rich?
Or do I do the standard reset and learn?
ASSUMing you have a 99^, the TB is quite big, and
actually about all the stock crossover tube cna handle anyway.
So just 1/2 shaft it and port the crossover tube. Great match,
and you get more airflow thru there for minimal effort.
Using anything bigger takes excessive crossover tube mods.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Should i get a throttle body? blackonblack Pre-2005 V6 Mustang 21 12-07-2009 07:21 AM
throttle body ? wvstang5.0ho 1979-1995 Mustang GT 16 07-29-2008 10:48 AM
throttle body sonicpony Pre-2005 V6 Mustang 2 09-09-2007 12:23 AM
Throttle Body Scut95 1979-1995 Mustang GT 4 07-01-2005 10:50 AM
70 or 75 mm throttle body????? greg_g70 1996-2004 Mustang GT 9 12-20-2004 09:58 AM
09:24 AM
