maximum motorsport gt & v6 questions - Mustang Evolution
Old 06-23-2005, 04:31 PM   #1
Send a message via AIM to tedness
ok im looking to buy some suspension stuff from MM...
namely the strut tower brace....designed for the GT, will it fit for the v6 or will anything be in the way as far as the engine is concerned.
also is it noticable or worth it to get this? in conjunction w/ the following parts:
- rear sway bar
- ford c springs
- mm rear lower control arms
tedness is offline   Reply With Quote
Old 06-23-2005, 04:33 PM   #2
get subframe connetors before that stuff.
Old 06-23-2005, 06:26 PM   #3
97Stallion's Avatar
Contact me for this suspension stuff, I can work you some sort of deals possibly on some of that stuff. Sub-frame connectors will do wonders for your car though.
Living one day at a time!
Old 06-23-2005, 10:54 PM   #4
Subframes make a big difference by themselves. My setup is c springs 1/2 coil cut front and back, tokiko s/s, bullitt front and rear sways, and steeda midlength subframes. Got them from rob.
Old 06-24-2005, 01:51 AM   #5
97Stallion's Avatar
Cool, so I'd say you're happy with them??
Old 06-24-2005, 02:40 AM   #6
now you just need bigger wheels to make those wheel wells look full
Old 06-24-2005, 07:30 AM   #7
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
call MM. they have good customer support
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 06-24-2005, 07:37 AM   #8
Danger Dude's Avatar
I would honestly not buy any high dollar strut tower brace and just get a Ford one. I have seen several manufacturers STB and they all look the same. Actually Steeda is a Ford unit with a Steeda sticker on it. Get a used one from some place like midwest mustangs or get one off of Ebay
Old 06-24-2005, 08:50 AM   #9
slvr2000stang's Avatar
subframes, get full length.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 06-24-2005, 10:17 AM   #10
something i wanted to ask you, would you say they are worth it? i drove my buddys riced out gt with and without the stb and i could feel no difference. isnt the front sway bar enough?
Old 06-24-2005, 10:47 AM   #11
Tbird232ci's Avatar
the strut tower brace is to keep the strut towers from moving independantly from eachother, and to keep them from moving at all, the swaybars job is to keep the body from rolling
the thing is, your cars are all so new, that your chassis are still relatively stiff, and rigid, do all the bracing you can, because over the years, your car will become more sloppy, and then youll feel the difference of all the parts, because they are absolutely needed
Old 06-24-2005, 10:55 AM   #12
If you have a 79 to 98 the answer is yes they are worth it. If you have a 99 up the answer is debends if you autocross. If you a a drag racing guy NO If you are a street and boulevard blaster NO. If you are a mountain carver or autocrosser Maybe to Yes
99+ have much improved strut towers in terms of strength and rigidity and dont require STB's unless extreme driving conditions
lower sway bars mean nothing to Strut Tower flexing under hard cornering
Old 06-24-2005, 11:04 AM   #13
some C springs have coils already cut.. so be careful of these so you dont go and cut more... lol
Old 06-24-2005, 11:16 AM   #14
If that is the case the top aft dead coil which is only half round will already be missing
Old 06-24-2005, 08:36 PM   #15
Yeh...I know...I want 18's but I can't make myself fork over rubber cash.
Just ordered 4 bolt Maximum Motorsport camber plates Vash Mustang Audio & Video 7 03-08-2006 07:24 PM
Fox 8.8 w/ Motorsport 3.55s Jayber Mustang Parts for Sale and Wanted 1 06-16-2004 06:06 PM
03:40 PM
