c-springs & mm plates....ok w/o shocks struts? - Mustang Evolution
Old 06-27-2005, 04:35 PM   #1
Send a message via AIM to tedness
is it ok to install the c-springs and c/c plates w/o upgraded shocks/struts?
as in how long can my stock shocks and struts handle the springs before needing to be replaced. i've heard mixed thoughts.
tedness is offline   Reply With Quote
Old 06-27-2005, 05:43 PM   #2
If you don't cut the front springs you won't need c/c plates...but I do since I cut mine. As far as stock and strut life, it all depends on how low you go. If you go without cutting, you may be ok for a while, if you cut it to my height, I dunno how long they'd last.
Old 06-27-2005, 06:01 PM   #3
saw your cardomain and it looks pretty stock height there. is it cuz of the tires and lighting or are those outta date photos?
i guess it isn't that hard to cut that dead coil?
any direction it needs to be cut in or specific point?
Old 06-27-2005, 09:43 PM   #4
Car domain is way outta date. Here's a pic of it, in the grass, and dirty, but you get the idea.
Old 06-27-2005, 11:03 PM   #5
it will be fine, the mm cc plates even raise the strut travel a bit... but not much. You wont have a problem for a good bit (I have like 30k or more on my shocks/struts with c springs)
Shocks & Struts wvstang5.0ho 1979-1995 Mustang GT 7 07-23-2008 11:27 AM
shocks, struts, and springs on a 79 notch Taywi Classic Mustangs 8 03-13-2007 11:41 AM
shocks/struts with c springs electricstang Pre-2005 V6 Mustang 16 06-30-2006 10:42 PM
shocks/struts/springs etc. 01mineralgrey6 Pre-2005 V6 Mustang 10 09-06-2005 03:51 PM
Shocks and Struts with springs? steedav6builder Pre-2005 V6 Mustang 16 07-13-2004 09:42 AM
07:50 PM
