what chip should i use - Mustang Evolution
Old 06-29-2005, 07:29 PM   #1
Send a message via AIM to CCstang2004 Send a message via Yahoo to CCstang2004
Alrite i know a guy named kevin that opened his own shop in columbus. He is a SCT guy and says that the SCT chip is the best. Im not so sure about it so let me ask yall. I want too add a chip im looking at the SCT chip or a jet chip, which one is the best and would give me the best bang for the buck?
CCstang2004 is offline   Reply With Quote
Old 06-29-2005, 07:32 PM   #2
I would talk to justin (he is on the site) he does SCT tunes, also americanmotorsports.com
until you have many mods a chip will do next to nothing for performance, consider it a good bolt on... if its dont correct and not just an off the shelf generic.
Old 06-29-2005, 07:37 PM   #3
Well would it be good to just go ahead and get the 3 program SCT chip so i can go ahead and put a perforamnce tune on it just until i can afford to get my supercharger put on?
Old 06-29-2005, 07:39 PM   #4
I would do everything at once, and get one tune for it.... unless your gonna run nitrous and then you will need atleast 2 tunes....
Old 06-29-2005, 07:46 PM   #5
they make hand held programmers that you can send off and have redone to mess with things... and your car wont be with out a program for XX days.
I would sit down and figure out where I wanted to end up, realistically... and then determine whats needed to get you there and in what order. Ask us in order to determine what all is needed to get there of course. Just figure out what the end result will be. A bolt on car or a full out bulit motor etc etc... just be realistic about it.
Old 06-29-2005, 07:49 PM   #6
In all honestly i just want too be able too go to the track have a good time maybe pull the tires and run some good times and maybe beat a drag car if im lucky. But i realalistically want a car that is more bolt ons then alot of motor work i may have the money just not the time to be having my car in and out of the shop when i have a job.
Old 06-29-2005, 07:56 PM   #7
I would just buy all the bolt ons at once and then get it tunned, run that for a while and see how happy you are.
dual exhaust, cold air intake, under drive pulley, aluminum driveshaft, shift kit if auto or shifter if manual, rear end gears, rear tlok unit, or just an 8.8 rear with your choice of gears ) then finish off with a tune.
All of that is not a bad start... in the performance area. Get a tune after all of that from a GOOD source and you should be good to go for a bit.
Old 06-29-2005, 07:57 PM   #8
Danger Dude's Avatar
We have like 4 people who are SCT tuners on this site. Anyone of them will be helpful. Justin at VMP is a super guy so is Mik at RPM
Old 06-29-2005, 08:04 PM   #9
Ok you said get a new shifter i have driven both the steeda tri-ax and the pro 5.0 in my friends moms mustang V6 but i like them both, i kinda like the tri-ax because it is spring louded but i like the pro 5.0 cause i can make quick shifts. What kinda shifter do you guys recomend if i want too run a turbocharger?
Old 06-29-2005, 08:30 PM   #10
slvr2000stang's Avatar
SCT is the only way to go.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 06-29-2005, 08:37 PM   #11
www.shiftergasket.com
Get you a Tri-Ax from him and tell him Brent sent ya. You get a free shifter gasket along with it.
Old 06-29-2005, 08:40 PM   #12
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
a turbo pretty much requires extensive engine work. it's not a simple bolt on
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 06-29-2005, 09:02 PM   #13
97Stallion's Avatar
I'll give you the same deal as well. www.RDmotorsport.com
Living one day at a time!
Old 06-29-2005, 09:38 PM   #14
alright thanks yall, let me get my car back out of the shop and see what all im gonna do then i will go ahead and order the stuff.
Old 06-30-2005, 09:22 AM   #15
Send me an email, I can send you some info and prices. Justin@VMPtuning.com
The best way to go is the SCT Xcal2 flasher, it gives you the most flexibility for upgrading and tuning later on. An SCT chip is a less expensive option though.
On Premium fuel a stock car will see a gain of about 7-12rwhp, 7-12rwtq, this is all across the RPM range, not just peak gains. You won't find many mods that add power everywhere. Throttle reponse will be greatly improved, which really helps the 5spd cars at the track. If you have an auto it can be made to shift much better. Most bolt ons, such as CAI, UD pulley, duals, spacers, don't require a different tune. You can easily drop .3 at the track with an SCT tune.
Also, just having a tune does not change the way HP from mods adds up, duals and a CAI may be 5rwhp+5rwhp, and an SCT tune adds another 12rwhp, but together or apart they all add up the same.
People used to say do all your mods first and then get a tune, this really isn't true unless you are talking major mods like heads/cam or a blower.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 06-30-2005, 11:27 AM   #16
Ok i do have a question what if i just went ahead and saved the money and got the chip and the Xcal at the sae time would that be a little better off, or would i just be wasting money?
Old 06-30-2005, 11:31 AM   #17
You don't need both, just one. The chip plugs into the port on the computer, and now the computer reads the tune off the chip. The xcal just flashes a new tune into the computer.
Justin Starkey
Old 06-30-2005, 11:32 AM   #18
ok i understand what you mean.
Do you need a chip? snydermj 2005-2010 Mustang GT 16 09-11-2009 07:54 PM
Chip Gray Ghost 1996-2004 Mustang GT 6 04-02-2009 10:04 AM
chip Sublime782 Pre-2005 V6 Mustang 11 06-09-2005 03:32 AM
f2 chip ttpancakes Pre-2005 V6 Mustang 3 07-07-2004 11:46 AM
Chip ERICK Pre-2005 V6 Mustang 2 08-08-2003 06:50 AM
03:48 AM
