how much gain from sct flasher? - Mustang Evolution
Old 06-30-2005, 11:56 PM   #1
Send a message via AIM to tedness
assuming i put all the variables in correctly, what kind of hp gains can i see when flashing? i've heard mixed, anywhere from 5-25rwhp
tedness is offline   Reply With Quote
Old 07-01-2005, 06:16 AM   #2
slvr2000stang's Avatar
On a mild bolt-on to fairly stock car same as an SCT Chip 7 - 12 rwhp.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 07-01-2005, 06:29 AM   #3
http://www.sctflash.com/main.php
everything you need to know
Kyle is offline   Reply With Quote
Old 07-01-2005, 07:41 AM   #4
Realistically, on premium fuel, 7-12RWHP, 7-12RWTQ and thats from idle to the rev limit. Improved throttle reponse, better shifting if you have an auto, removed speed limiter, raised rev limiter. Send me an email if you want some more information.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 07-01-2005, 08:49 AM   #5
Uh oh...you're in trouble now. You said raise the rev limiter. Spector is gonna yell at youuuu....lol.
Old 07-01-2005, 09:23 AM   #6
My WOT shifts have been around 6000 for several years now.
Good maintenance practices are key when running a car hard.
I keep to strick oil & tranny fluid changes & monitoring.
2000 Vert 4R70W
Old 07-01-2005, 09:43 AM   #7
I don't doubt it...but Spec was has been giving 04Stang a hard time about having the rev limiter over 5500...as you probably saw in the thread about 04stang and his new SCT tune.
Old 07-01-2005, 10:46 AM   #8
I liek gramer
WhiteStang99's Avatar
Spector doesn't think you should do anything to a car other than make it look pretty.
People do like to go fast in their cars!
Old 07-01-2005, 02:50 PM   #9
ouch lol. spec? any input?
Old 07-01-2005, 05:47 PM   #10
I dont think you should just make your car look pretty... Im OCD about keeping your car in perfect working order... lol thats all. I have raged the crap out of cars before... Ive just grown up a bit and know the consequences to messing stuff up (I had to be towed home from an hour away cuz i broke my car at the track....)
I like performance just as much as looking good if not more... but being stupid and having a good performing car are two different things. the only advantage to shifting past your peak is to keep the rpms higher for the next gear.
valve float will happen about 5700-5900... thats very very bad if you want to go to 6k then go for it... but have some money saved up for motor repairs, you may never have an issue... but you may so just make sure you know what you are getting into.
Like i said im OCD about keeping my car in perfect working shape, there is a time to have fun with it of course but I dont go around doing burn outs and all that crap every day, just now and again wait till I get my next car and tell me I dont worry about performance
oh and once you break the **** out of your car... you will have a little more feel for takign care of it as well
Old 07-01-2005, 05:53 PM   #11
How do you know thats where valve float happens? You don't. Ford tests the motors to a much higher RPM than that, and usually sets the rev limiter 600rpm below that.
A 6000rpm rev limiter (400rpm higher than stock) is completely safe with a stock cam and stock valve springs, I would program a chip or flasher with a 6k rev limit if it was not safe.
Justin Starkey
Old 07-01-2005, 05:58 PM   #12
Im sorry, you are correct in the above. I was confused, the stock rev limiter for his and my car as well is 6k rpms. I was also way off on the valve float... lol I dont know what got me thinking that... oh well. If I had known you were the one that done it I wouldnt have said anything cuz I know you know what you are doing. He had just mentioned someone that was local and im sure they dont know as much as you or one of the other good tuners do.
Old 07-01-2005, 09:17 PM   #13
i wish i could have all this done b4 the trip..
Old 07-01-2005, 11:44 PM   #14
Send a message via AIM to NJStang86
I <3 my Xcal2
-Frank-
http://home.earthlink.net/~riz3742/sig2.jpg
2003 Ford Mustang Dark Shadow Gray Coupe - 15.616 @ 87.24 (work in progress)
NJStang86 is offline   Reply With Quote
Old 07-02-2005, 02:15 AM   #15
bbunt302's Avatar
Spector is right about raising the rev limiter on a near stock car though. There's no need to rev to 6000 when power peaks at 5200 (or whatever the V6 peaks at, not sure on that). There's no reason to be shifting a car that peaks power at 5200 anywhere near 6000 rpm. All you're doing then is increasing valve-train wear and risking valve float, because your definitely not making any power.
Scary stuff.
Old 07-02-2005, 09:17 AM   #16
On a 4spd automatic the gears are spaced so far apart that shifting at a higher RPM keeps you in the powerband when you shift into the next gear. My auto V6 ran faster NA with higher RPM shift points, and SilverStang's does too.
On a 5spd with closer gear spacing I agree that shifting at a higher RPM is not beneficial, but at least if you shift a little late at the track or while bracket racing you don't hit the rev limiter and trash the whole run, you just run a tiny bit slower whereas with a stock limiter you would of hit it and lost some time.
Justin Starkey
Old 07-25-2005, 01:48 PM   #17
a 6k rev limiter is really only needed if you have a new cam/heads and new valve springs that can handle the stress. recently got my new SCT X-cal2 from justin and the rev limiter is at a little over 6k and it makes power all the way up to that point, then pulls even harder through 2nd and 3rd. i also have new cam and heads. the chip is worth the money, especially for a modded vehicle and even for a stock one. a stock one will get better gas mileage, a little more hp, and better shift points (autos). when i hooked up the flasher the car ran much better and smoother than before, even with my loopy idle from the cam. but my car now truely sounds like a v8. even the guys with GT's think i have av8 in my car, its great.
bigpomps is offline   Reply With Quote
Old 07-25-2005, 01:50 PM   #18
your car will simply be much happier with a chip/flasher with or without mods in it. spend the few hundred bucks and get one, you will be much happier.
Old 07-30-2005, 11:54 AM   #19
Danger Dude's Avatar
Personally I would wait and do a chip in stages. I would not buy one on a bone stock V6 and then need one when you do gears. Plan your mods smartly, do not deviate unless you absolutely have to. A well laid out plan of modding will save you a bundle I PROMISE!!!! Been doing it for 25 years
Old 07-31-2005, 07:07 PM   #20
The SCT X-cal2 allows the user to adjust the tire size and rear end gear ratio (only 99+ can have the speedo correct this way, older vehicles have to use a speedo gear). So that is another option. Also, the SCT chip holds up to 4 custom programs so 2 could be for stock gears and 2 for your future gears.
Justin Starkey
Old 07-31-2005, 07:20 PM   #21
Originally Posted by NJStang86
I <3 my Xcal2
me too
Old 07-31-2005, 07:22 PM   #22
The SCT X-cal2 allows the user to adjust rear end gear ratio .
is that only when you get a different set of rear end gears?
Old 08-02-2005, 07:11 AM   #23
Re: how much gain from sct flasher?
Yes, when you change the rear end gears you have to fix the speedo, on 99+ you can do this through the computer.
Justin Starkey
HP GAIN ? Gt.Vert 1996-2004 Mustang GT 35 04-20-2010 09:19 PM
SCT chip or SCT Programmer? ninty6stang 1996-2004 Mustang GT 7 07-02-2008 11:57 AM
New SCT X-Calibrator Version 2 Flasher and Datalogger justin00stang Pre-2005 V6 Mustang 2 06-04-2005 09:18 PM
10:26 AM
