Punch a hole in my oil pan for my vortech - Mustang Evolution
Old 07-02-2005, 12:09 AM   #1
Send a message via MSN to danstang Send a message via Yahoo to danstang
Well i decided to go with a vortech supercharger to run 14's i already did everything installed all that needs to be installed but i got stuck where you need to punch a hole in your oil pan it looks like its risky, cause you might punch a bigger whole. So i was wondering is there another way of doing this without punching a whole in my oil pan. any of yall have pics of the hole or of the installion.
oh one more thing whats the stock size of the injectors for a 98 v6?
Thanks
danstang is offline   Reply With Quote
Old 07-02-2005, 12:25 AM   #2
Stock size is 14#
Dunno the answer to the first question
Old 07-02-2005, 12:52 AM   #3
drill the hole with a PROPER sized drill bit, just compare it with the line that goes into tha hole and amke sure the bit is just a bit smaller.
Old 07-02-2005, 10:05 AM   #4
97Stallion's Avatar
You have NO other way of doing this. The reason for this hole it because Vortechs use oil, and the hole is so the line can drain the used oil back into the oil pan. What I would do is take off your timing cover. Mask off the inside with tape or rags so the shavings won't go into the oil. This way you can make sure you get all the aluminum shavings out and won't have to worry bout it.
Living one day at a time!
Old 07-02-2005, 12:55 PM   #5
Send a message via AIM to tedness
14#? i thought they were 19#...or is that on mine....
i miss the blower...
tedness is offline   Reply With Quote
Old 07-02-2005, 04:09 PM   #6
Kiljosh's Avatar
19's on 99-04
When you do drill, do it slow. Use a drill with different speeds if you can. The slower you go the less chance you have of pushing through and sending all the shavings caught in the bit into the oil pan. I would suggest doing what rob said.
Old 07-02-2005, 05:14 PM   #7
like was said..drill slow and even use some drill lubricant. It will help to keep all the shaving together and out of the pan.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 07-02-2005, 05:24 PM   #8
i would take the pan off... you do NOT want to get metal shavings in your oil...
Old 07-02-2005, 05:40 PM   #9
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
should have gone procharger. they have their own internal oil supply
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 07-02-2005, 07:07 PM   #10
I would go turbo 3400 bucks~ anything you do will be great... just tap that hole and dont get shavings in your motor.
Old 07-03-2005, 03:06 AM   #11
Yeah i was thinking of the procharger but it comes with 11 psi and didnt know if my 96k v6 would handle that kind of boost. would it be able to handle it
Old 07-03-2005, 12:46 PM   #12
they have a 9psi pulley you can use as well.
Old 07-03-2005, 01:01 PM   #13
the 9psi is better on the older v6 blocks.
Old 07-10-2005, 10:29 PM   #14
Send a message via AIM to hoof
It took me 6 hours on a creeper to pull and reinstall my oil pan, and when you are done you need an alignment because you have to drop the k-member to make room. I would follow the directions and be careful, pulling the pan SUCKS!!
hoof is offline   Reply With Quote
Old 07-11-2005, 02:45 PM   #15
Tbird232ci's Avatar
still need a drainback for a turbo
Old 07-12-2005, 01:07 PM   #16
First off you need to use a roto-broach not a drill bit. Its like a hole saw and allows you to cut the hole to the exact size and keep the cut material out of the pan.
I would also suggest that you have a bung tig welded to the pan as there isn't much material there to tap for the piece to thread in to.
Its not hard to do but you need to take your time and do it right the first time. The bung will help you out HUGELY.
96 GT 4.6 L
Ported 2004 Upper Plenum
B&M Shifter
Bassini O/R X Pipe
FRPP Adjustable Clutch Cable
UPR Extreme Triple Hook Quadrant
UPR Extreme Firewall Adjuster
Ford 11"Clutch Conversion
C&L MAF
WMS CAI
Aluminum Drive Shaft
95 V6 Vert: 4.2L swap, Trac Lock, Light Cam, Mac Shrorty Headers, More to come.
AlmostN8 is offline   Reply With Quote
Old 07-12-2005, 11:23 PM   #17
97Stallion's Avatar
I agree with this about 1000%. If you get a bung welded to your oilpan, you'll add some extra material and you'll get a more positive seal when you tap the hole.
Old 07-13-2005, 07:31 PM   #18
start with a small tap and work your way up in size. i wouldn't advise using a drill because of the shavings. use some grease on the tap to catch the shavings from the tap. turn the tap slowly in and out so the shavings stick to the grease. change the oil right after tapping the pan if you do it with the pan on the car. you can also buy an oil plug with a magnet on the inside end to help catch any metal in the oil.
My 1999 Mustang GT Vert 35th Ann. L.E. (4R70W) mods and pics
380rwhp & 377rwtq. 12.697@110.06 street tires and pump gas
2004 Focus SVT #1699 - daily driver
Distortion File: Your car, news, chat, and media stoplight.
dbmstng is offline   Reply With Quote
Old 07-13-2005, 07:54 PM   #19
97Stallion's Avatar
While this is true, aluminum is not magnetic, so it will not be caught by the magnet. I don't know how much I can stress that I would definately remove your timing cover. You'll be able to have access to both sides of where you're working and you'll also be able to ensure you remove all the debris you will be creating and you won't have to be as careful while punching the hole and tapping it. I not saying that you can do this care-free. I'm saying you don't have to be extremely cautious that you get all the shaving on the outside of the pan. If you place a rag on the back side of the hole you drilled, then you'll be all good and will be able to look physically if you got all the shaving instead of hoping.
Definately sure = 100% safe
Pretty sure = 1-99% safe
Not sure = not safe
Old 07-20-2005, 08:21 PM   #20
it isnt that hard
TexaStang is offline   Reply With Quote
Old 07-20-2005, 08:28 PM   #21
Danger Dude's Avatar
Originally Posted by Kiljosh
19's on 99-04
No 21's on 99+ v6's
19's were on 5.0 and 4.6's till 98
need help removing my oil pan! jkaminski24 1996-2004 Mustang GT 7 08-23-2010 05:54 PM
WTB 01+ Crank pulley and Oil pan ebalderas Mustang Parts for Sale and Wanted 0 01-03-2009 12:06 PM
OIL PAN REMOVAL MR.PEE Pre-2005 V6 Mustang 2 05-01-2008 07:00 PM
Oil pan question... lowflyn Pre-2005 V6 Mustang 9 03-15-2006 06:14 PM
Possibly found metal in my oil pan!!! Horse Pre-2005 V6 Mustang 5 09-23-2005 01:39 AM
07:44 AM
