when unhooking battery.... - Mustang Evolution
Old 07-02-2005, 11:57 AM   #1
Send a message via AIM to tedness
can i just electrical tape the terminal end down to a plastic piece? or can it go anywhere so long as it doesnt touch terminal?
tedness is offline   Reply With Quote
Old 07-02-2005, 02:42 PM   #2
fast64's Avatar
as long as the cable isn't touching the positive terminal your fine.
GO BRAVES
Old 07-02-2005, 04:31 PM   #3
bend back the terminal wire so there is NO chance of touching, I always take the negative off.
Old 07-02-2005, 05:21 PM   #4
redfire2003's Avatar
take the negative off it takes the ground out of the system
redfire2003 is offline   Reply With Quote
Old 07-02-2005, 07:30 PM   #5
NorwegianMustang's Avatar
Send a message via AIM to NorwegianMustang Send a message via MSN to NorwegianMustang Send a message via Yahoo to NorwegianMustang
Mods: Magnapacks, BBK X-pipe with cats, BBK CAI, hood struts, KYB Shocks/Struts, Eibach Pro springs, SS Inserts, CDC Light bar, Chrome 17" Bullits with Nitto 555 and N2O with dual purge
NorwegianMustang is offline   Reply With Quote
Old 07-02-2005, 08:10 PM   #6
jimmy_beaner's Avatar
Region: Iowa
ever try to jump a friend's car with wire.. and get them crossed as your'e holding it with bare hands? I have
Old 07-02-2005, 08:54 PM   #7
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
when i unhook my battery to do work or whatever i usually lay down a dry towel or something over my battery that way theres no chance of it hitting
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 07-02-2005, 09:14 PM   #8
i made sure nothings touching. it should be fine. finishing up in the morn
Old 07-02-2005, 10:19 PM   #9
Ponycarman's Avatar
You should always remove the negative cable before you remove the positive cable. Why? Simple, if you are removing the positive cable and you happen to touch the body or other ground with it still connected you get a big old spark and if you are really unlucky you'll weld the wrench inplcae and start a nice fire and maybe a battery explosion raingi acid all over you, usually in your face.
If you remove the negative cable first you don't have that issue. I usually bend it down and out of the way.
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
is it time for a new battery??? Rollin Thunder 1979-1995 Mustang GT 6 04-04-2008 06:47 PM
battery light carlosc Pre-2005 V6 Mustang 4 09-18-2007 09:34 PM
Battery help lowflyn Pre-2005 V6 Mustang 8 11-26-2006 01:29 AM
Battery Light fordfan1184 Pre-2005 V6 Mustang 2 08-27-2003 03:16 PM
03:33 AM
