IAT inside intake pipe, still check engine light - Mustang Evolution
Old 07-04-2005, 02:37 PM   #1
Send a message via AIM to tedness
i did all the work w/ the battery disconnected. and then re-hooked it up. for a while it had no engine light on, but now it came back on.
what could it be? everything's working properly but the light still comes on.
would it help to disconnect the battery again?
tedness is offline   Reply With Quote
Old 07-04-2005, 05:07 PM   #2
Kiljosh's Avatar
Disconnect the battery for 15 minutes and reset the computer and se eif it comes back on.
If it does then goto Autozone and get it checked out, get the code and come back. It may not be your IAT.
Old 07-04-2005, 08:10 PM   #3
slvr2000stang's Avatar
Check that all of the connections on the intake tube are correct & not leaking.
Make sure everything is connected. Like the passenger side valve cover to intake tube line of the PCV.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 07-04-2005, 08:50 PM   #4
how do i reset the comp? just by disconnectin battery?
Old 07-05-2005, 04:27 PM   #5
Kiljosh's Avatar
yea, but for a long time, maybe 10 minutes but I think its 15.
Old 07-05-2005, 06:13 PM   #6
ya...it turns out my sensor is damaged i believe. the code at autozone said check it and blah blah. my ford guy is gonnna take a look-see
Old 07-05-2005, 07:34 PM   #7
Region: New Hampshire
Send a message via AIM to Smokedya95stang
What was the code?
Dont listen to what those autozone people have to say their retarded.
-Charles
Smokedya95stang is offline   Reply With Quote
Old 07-05-2005, 08:30 PM   #8
check IAT connections, etc.
i tred it in the pipe, outside it, in the fender, everywhere.
so my homie is gonna double check it.
check engine
Check Engine Light - Help! Eeyore General Mustang Discussion 15 04-23-2009 07:26 AM
check engine light avery_y Pre-2005 V6 Mustang 9 01-13-2007 06:16 PM
Check engine light avery_y New Member Introductions & Greetings 0 12-09-2005 09:58 AM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 1 08-03-2003 08:24 AM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 2 07-30-2003 12:22 AM
06:28 PM
