Changing to a 4.2L? - Mustang Evolution
Old 09-23-2009, 11:16 AM   #1
Changing to a 4.2L?
Im 18 got my 3.9L v6 04 mustang for my first car and besides a K&N cold air intake i havent done anything. I read in threads that turning it to a 4.2L would be good. How much is it gonna cost. how is it done? im ok on cars but idk what exactly needs to be switched? any adjustments to the chip, tranmission, backend? Am i swapping out for an entirely new engine? and what problems am i gonna run into.
devon is offline   Reply With Quote
Old 09-23-2009, 03:50 PM   #2
hottcobra's Avatar
Re: Changing to a 4.2L?
You would have to remove your stock engine and either bore and stroke your engine or buy an already built engine. The computer will have to be retuned, but everything else will go right back.
Old 09-23-2009, 04:27 PM   #3
This should give you some guidance:
http://www.mustangevolution.com/forum/t9601/
19Delta is offline   Reply With Quote
Old 09-25-2009, 09:55 AM   #4
01-up split port heads
- 4.2 shortblock or longblock
- You can use the 4.2 heads
- Mustang upper and lower intake and fuel rail
- Mustang 3.8 water pump
- Auto trans = your stock flexplate
- 5spd = your stock flywheel and a pilot bearing
- V6 Mustang bellhousing
- Re-use your stock cam position sensor
- Your 01-up 3.8 oil pan
- Your 01-up 3.8 oil pick-up tube and screen
- Your stock 01-up 3.8 damper
- Re-use the stock 3.8 oil pressure sender and tube
- Re-use the Mustang headers
- You can use the 4.2 or 3.8 dipstick. Just keep track of where 5 qts puts the mark when refilling with oil.
will all this be compatible with my 3.9L its alot like the 3.8 and idk the differences but it sounds like it should work. my only question from here is what is a good car that i can pull the engine out of in a junkyard?
Old 09-25-2009, 01:45 PM   #5
Maybe a ranger or an explorer, that's my guess :dunno:
Old 09-25-2009, 06:40 PM   #6
upton7's Avatar
I'd take it out tear it down replace bearings clean everything up then bore it. And get a crank from a ford truck. Its alot more fun.
changing my grill PenguinFan Mustang Audio & Video 6 07-26-2009 06:43 PM
Changing coolant soon Mustangfan2003 1996-2004 Mustang GT 9 10-14-2008 08:15 AM
About changing oil... Ibanezplayer272 Pre-2005 V6 Mustang 21 02-23-2006 09:33 PM
mind is changing... 98GreenStallion Pre-2005 V6 Mustang 25 02-10-2005 06:27 AM
changing it up theglory Pre-2005 V6 Mustang 29 01-14-2005 06:34 PM
06:31 AM
