RPM drop - Mustang Evolution
Old 07-15-2005, 05:19 PM   #1
Send a message via AIM to Murph00
RPM drop
Ive noticed lately when I brake mild to hard like for a stop light, my engine rpm will drop near or below 500 and begin to do the chug thing like its gonna die. its a manual so I rev it when this happens. do I need to clean my throttle body?? or what might this be (55,000 miles)
Murph00 is offline   Reply With Quote
Old 07-15-2005, 05:28 PM   #2
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
be sure your clutch is pushed down all the way
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 07-15-2005, 05:39 PM   #3
Is your clutch acting up any? Is your a/c on? etc etc.
Old 07-15-2005, 05:49 PM   #4
my clutch is fine that I know of, I have a syncro problem with 5th gear but thats it
Old 07-15-2005, 05:55 PM   #5
Ponycarman's Avatar
Clean your IAC. It is what controls your idle speed and a sticky one might do this.
Also, as I am not a Ford guy this may not be relevant, but on EFI Mopars there is a speed senspr connected to the computer. When it starts to fail (wrong pulse counts but not dead) then you get this symptom.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 07-15-2005, 06:33 PM   #6
clean your maf with some no residue contact cleaner for electrical parts (radio shack or autozone has it) then clean the idle bypass valve, its on the upper intake behind the TB.
See if that helps, do you run your AC? mine idles low if I run it and I am stopped.
Old 07-15-2005, 07:20 PM   #7
Old 07-15-2005, 07:22 PM   #8
Wow...a repost 2 hours later...lol.
Old 07-15-2005, 07:28 PM   #9
Danger Dude's Avatar
I would also check for vacuum leaks.
Old 07-15-2005, 09:06 PM   #10
Send a message via AIM to tedness
mine did that for a bit when i put the CAI on. then once the ECU learned the new air flow settings it fixed it.
a few times it stalled me out too
so i don't think its clutch related
tedness is offline   Reply With Quote
Old 07-15-2005, 09:29 PM   #11
97Stallion's Avatar
I was thinking the same thing. There are few things that would cause Vacuum leaks. A sticky TB plate will cause the TB to stay open a little, so you can check that as well.
Living one day at a time!
Old 07-15-2005, 09:41 PM   #12
Also check the hose that goes from the Brake booster to the upper intake. It can dryrot and get brittle and crack.
Old 07-16-2005, 12:32 PM   #13
mine does the low rpm thing from tiem to time, i clean the maf and it goes back to normal.
rpm drop classman Pre-2005 V6 Mustang 9 07-22-2010 07:59 AM
drop in mileage gregor Pre-2005 V6 Mustang 2 04-08-2007 09:33 PM
2" drop too much? tedness Pre-2005 V6 Mustang 8 03-31-2005 07:31 PM
How about a drop? Ken The Bar 22 09-16-2003 08:25 PM
need a drop hmongstang The Bar 20 08-12-2003 09:48 AM
11:36 PM
