pinging with my chip - Mustang Evolution
Old 07-16-2005, 02:58 PM   #1
Send a message via AIM to Sublime782 Send a message via Yahoo to Sublime782
Hey all, I have a 2002 v6 mustang. I just installed 3.73 gears and an auburn posi...they work great. I also got a chip from VMP to make up for the gear ratio. Anyway, I have 2 tunes; and 89 octance performance tune and a 92 octane performance tune.
Ok, I've only had it on the 89 octance setting since I've installed the gears. Yesterday, after running my tank to empty on 89 octance fuel I gased up with the premium stuff(92 octane) and away I went. As soon as I got up in the RPM's, I got the dreaded pinging noise (!!!!!!!) Anyway, After a few blocks I stopped my car and switched it back to the 89 octane setting and bing, no more ping! (yay). Anyway, I'm assuming it was pinging because there was a little bit of the 89 octance fuel in the tank when I filled up with 92(even though the tank and almost empty and my low fuel light was on). Anyway, I'm thinking I'll just wait a day or so and let some of the lower octane fuel get burned out and then switch to the 92 octane setting on the chip and see if it still pings. Any input on that?
Also, will it hurt my car any to run 92 octane fuel on the 89 octane chip setting? I don't think so, but I just thought I'd check with you guys.
Cheers,
James
Women are like parking spots; the best ones are either taken or handicap
Sublime782 is offline   Reply With Quote
Old 07-16-2005, 03:06 PM   #2
The timing may be advanced to much. Give it about 20 miles of driving and then switch it to the 92, give it a run and if it still pings send the chip back and have it reburned because it should not be pinging.
Make not the rpm range of where it starts pinging up until whenever your car shifts.
Old 07-16-2005, 06:10 PM   #3
Danger Dude's Avatar
where do you live. If you live in a Reformulated Gas state GOOD LUCK!!!!! It has been experienced by many in these states that the octane rating evidently dont mean much.
You can try something. Go to a Ace hardware store and buy a gallon of Toluene and mix it with a full gallon this will raise you octane about 1.5 points Do not buy Octane 104 that tiny little bottle will only bring your octane up .3 it is a joke.
Toluene is used by professional racers to raise octane
Old 07-16-2005, 06:18 PM   #4
yea reformulated gas sucks... good luck with it.
Old 07-17-2005, 10:16 AM   #5
Local gas quality or a lot of oil in the upper intake can cause some cars to ping. Its fine to put higher octane gas in the car than what the tune is set up for. I would put another full tank of premium in it, install some colder plugs, 22 or 32 motorcrafts, and do something with the PCV system. If that doesn't help or you don't want to go to all that trouble I can reburn the chip for you no charge.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Chip Gray Ghost 1996-2004 Mustang GT 6 04-02-2009 10:04 AM
what chip should i use CCstang2004 Pre-2005 V6 Mustang 17 06-30-2005 11:32 AM
chip Sublime782 Pre-2005 V6 Mustang 11 06-09-2005 03:32 AM
f2 chip ttpancakes Pre-2005 V6 Mustang 3 07-07-2004 11:46 AM
What is pinging? MustangNewB Pre-2005 V6 Mustang 22 04-14-2004 10:27 AM
04:36 PM
