Ported and Polished lower and upper intakes - Mustang Evolution
Old 07-18-2005, 04:05 PM   #1
Send a message via MSN to danstang Send a message via Yahoo to danstang
Im thinking of buying lower and upper intakes from http://rpm-mustangs.com/cart/home.php?cat=259 and wanted to know if anyone has bougth from here or has heard about their porting.
If i put the both ported and polished intakes do i need to upgrad injectors and fuel pump or can i just run it with the stock injectors and stock fuel pump.
what are the most common hp and tq gains and can i loose some time in my 1/4 mile
Current Mods
3.73 gears w/ ford racing posi trac diff
mac off-road h-pipe
mac cat back exhaust
bkk cold air
throttle body spacer
plasma booster
msd wires
short throw shifter
rears seat delet kit
danstang is offline   Reply With Quote
Old 07-18-2005, 04:38 PM   #2
they are one of the best, mike is very good. You will have good service and a high quality product. Mike can answer any of your questions for what you will need to run your set up, just email him and see what he tells you.
Old 07-18-2005, 06:55 PM   #3
Danger Dude's Avatar
I have RPM BV heads, Cam, Lower intake and RGR upper intake. All very good quality
Old 07-18-2005, 07:45 PM   #4
slvr2000stang's Avatar
You will be fine with the stock parts
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 07-18-2005, 07:52 PM   #5
i forgot to mention mine is a 1998 v6 and after i put both intakes can i use a predator programer and it will work fine
Old 07-18-2005, 08:01 PM   #6
Yes But I would go with an SCT product.
2000 Vert 4R70W
Old 07-18-2005, 08:12 PM   #7
OK for Ported upper and lower intakes without doing heads or cam you dont need to be reprogramming. The cars computer will make adjustments to the change in airflow. Until you get heads and a cam you wont need bigger injectors or different fuel pump, 98 was the first year the V6 had the same pump as the GT. I would also recommend what Kirk said above and use a SCT chip or tune. We have a couple of tuners who are sponsors on the forum
Old 07-18-2005, 08:22 PM   #8
where can i buy the sct programmer yall said its for a 98 v6
Old 07-18-2005, 08:31 PM   #9
97Stallion's Avatar
You can get that from me at RD Motorsport.
Living one day at a time!
Old 07-18-2005, 08:38 PM   #10
do you have a website
what is the best sct programmer or which one do you recommened for my car
Old 07-18-2005, 08:59 PM   #11
97Stallion's Avatar
Yup, www.rdmotorsport.com. I would recommend just getting a chip or a flasher like the X-Cal2 unless you really want to get into your car. I have the racer package which runs for about $800, and that allows you to tune your own car, but you have to understand alot about how your car works and what everything means. It's not for the beginner really. I don't have the X-Cal on the site yet, but you can still get it through me.
Old 07-18-2005, 09:02 PM   #12
Monkey's Avatar
honestly, ported and polished intakes w/o cam or heads is pointless. You may see 10hp, but that's about it. port the heads and you will see 20. Get a cam, and you will see another 15-20
Old 07-18-2005, 09:06 PM   #13
how much is the x-cal 2 and does it work fine with the mods i have
Old 07-19-2005, 01:01 AM   #14
97Stallion's Avatar
The X-Cal2 is $350 and it will work with your car just fine.
Old 07-19-2005, 11:52 AM   #15
i found out theres two companies that make ported intakes for our engines its http://rpm-mustangs.com/cart/home.php?cat=259 and its http://www.supersixmotorsports.com/P...atalogrev1.pdf
which is the best or what do yall think
Old 07-19-2005, 02:00 PM   #16
Both are excellent companies either one would be a good choice. I used RPM but many people use SSM. It is really a toss up. Since Mikael @ RPM is a forum sponsor and a great guy he is going to get good reviews from many here.
This is something you will have to decide. I would contact both and listen to what they offer and make a decision for yourself. Either way you wont go wrong.
Ported & Polished Lower Intake VCS_SSSTANG Pre-2005 V6 Mustang 0 08-03-2008 05:23 PM
ported intakes/heads jmp782 Pre-2005 V6 Mustang 4 01-18-2008 05:22 PM
Ported Upper or Lower first? ntc432 Pre-2005 V6 Mustang 20 05-06-2005 07:04 AM
upper and Lower intakes coolstang Pre-2005 V6 Mustang 8 02-12-2005 11:26 AM
Ported and Polished Intakes greenpony02 Pre-2005 V6 Mustang 21 01-06-2005 02:43 AM
12:31 PM
